Old 11-28-2007, 08:06 PM   #1
PhilC64's Avatar
Member Number: 6496
Tap Tap Tap - Away!
There are several new forum members and FJ Owners who get rather atwitter when they hear the infamous Toyota Tap. Before heading to the dealer to get it looked at try this 50 cent mod!
This is a repost now with pics from MikesFJ regarding http://www.fjcruiserforums.com/forum...ping-idle.html
That annoying tapping sound you hear at idle is not your lifters, injectors or your headers. There is an emission control component called the PWM-vacuum switching valve screwed to the intake manifold on the drivers side. You can access it by removing the plastic shield over the intake manifold. It is held in place by a single screw. This thing activates when the vehicle is at idle and at temperature. Look in the red circled area for the general location of the PWM Valve.
To minimize the tapping sound coming from it, you nee to isolate this component from the manifold. The manifold is resonating the sound from the valve making it loud.
Here's what I did to minimize the noise:
You will need 2 rubber o-rings ( I used R03 nitrile o-rings) and a 10 mm Nutdriver or wrench.
After removing engine cover,
remove bolt that holds the valve to the manifold (no need to disconnect any lines or harness)
Place an O-ring on the bolt and push it to the head of the bolt.
Slip the bolt through the valve and slide the other o-ring over the bolt.
re attach valve tightening enough to compress the o-ring and snug the bolt. The o-rings should be enough to keep the bolt from vibrating out.
Replace cover and enjoy the silence! In picture 2 is the bolt you take out and place your isolator upon. I used very thick double sided tape in the same manner as described above!
***This may not eliminate this noise, but it sure quieted mine down.
So, don't worry about trying different weight oil (use the recommended only) or any other drastic measures. From what I have read, most if not all toyotas in the last 5 years have this tick. Maybe the factory should do something about it. I think that Toyota should find a quieter valve or make an isolated mounting kit.
Mud is also a sound deadener I opted for and have been applying slowly over the past several months!
07 FJC - de-modded back to stock
89 FJ62 - madly modded
74 FJ40 - SOA'd, Saginaw'd, locked, disc converted, 37" Goodyear MTR's and topless. Now with 2F tractor power
PhilC64 is offline
Old 11-28-2007, 08:29 PM   #2
fj in nepa's Avatar
Member Number: 13824
Re: Tap Tap Tap - Away!
nice fix
Sla'inte
BLK CHERRY
ATM, 4WHD
REAR DIFF LOCK
A-TRAC
OEM ROCK RAILS
TRAILGEAR TRANSFER SKID
TOYOTA BLACK STEEL WHEELS
MICKEY THOMPSON BAJA MTZ
REAR DIFF SCUBA MOD
R/C 3INCH LIFT
UNIDEN C.B
BANDI MOUNT.
SIRIUS RADIO
GARMIN NUVI 255w
BULL BAR WITH HELLA 500
T.L.C.A. #19204
http://www.fjnortheasters.org
fj in nepa is offline
Old 11-28-2007, 08:39 PM   #3
PhilC64's Avatar
Member Number: 6496
I found it a year ago and has saved me the headache ever since! There have been a couple of posts here and in "Engine Maintenance" regarding the "tapping" noise. I figured I'd repost a great cheap mod and give it a couple of pics for reference
PhilC64 is offline
Old 11-28-2007, 08:43 PM   #4
FJCamel's Avatar
Member Number: 11390
Hey phil, if u stay at this pace u will soon not hear the engine.
Mods NEVER Stop
DIGGER makes
them HAPPEN !!
http://www.discounttiredirect.com/direct/home.do
FJCamel is offline
Old 11-28-2007, 09:13 PM   #5
PhilC64's Avatar
Member Number: 6496
Thanks Abdul!
PhilC64 is offline
Old 11-29-2007, 01:12 PM   #6
FJ-Bomb's Avatar
Member Number: 14810
Maybe the Mods should make this a sticky if this is a fairly common characteristic...just a thought, but I am new around here, what do I know.
Phil thanks again for the help!
'07 Sun Fusion 4x4 A/T, Rear Locker, A-Trac, TRD CAI, Roof rack, Horn Mod, Brush Guard, PIAA 520's
FJ-Bomb is offline
Old 11-29-2007, 03:49 PM   #7
Banned
Member Number: 14075
Location: The Beautiful Pacific North West in Yakima, Washington
anyone else try yet ?
FJ CRUZER is offline
Old 11-29-2007, 03:56 PM   #8
yoda's Avatar
Member Number: 2584
Thanks for the info, that noise has been driving me nuts!!!!
07 FJ, At ,Upgrade #2,Toytec 1/2 FR Spacer,Auto Vent Shades,285/75/R16 Dick Cepek FC-11's on 16x8 Ultra 50/51's
yoda is offline
Old 12-02-2007, 12:27 AM   #9
DEWFPO's Avatar
Member Number: 7505
FJ CRUZER previously said: View Post
Try what yet..... the fix? Have you read thru the thread highlighted in the first post? A ton of us have. Takes 2 minutes, costs maybe 40 cents and gets rid of most of the loud tapping.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera.
"Enjoying the Journey"
DEWFPO is offline
Old 12-02-2007, 07:35 AM   #10
AF Chief's Avatar
Member Number: 6901
thanks for the info!
AF Chief is offline
