Antenna Base Replacement
5.1K views 14 replies 9 participants last post by  Hannibal
#1 · (Edited)
Hi I just wanted to post if your antenna base is getting old replacing it was super easy and took a few minutes.
is what I followed. I was surprised on Amazon this part is going for 7$ and did appear to be OEM. I didn’t see a specific thread on this just mentions so hopefully help some people out.
#2 ·
Those antenna grommets only seem to last about 10 years. So many FJs that I see have a deteriorated antenna grommet even though it is easy to replace.
In the video he used a 7mm wrench (held backwards) to remove the antenna. Toyota included the antenna wrench tool in the glove box with the FJ when it was new so that you could easily remove the antenna when going through a car wash or to prevent damage when off-roading. If you've lost your original antenna tool, it is Toyota part no: 863A2-0C010.
#12 ·
My antenna mast kept loosening up over time, once just caught it before it fell out completely. Threw some loctite red on it. The blue didn't hold well enough for some reason, and I even cleaned the two ends. Yes, that 'ornament' is pop-off/pop-on easy. The metal trim piece is a real PITA!
#13 ·
Wished I had this presence of mind the first time I ran mine through a car wash. Snapped like a twig. Didn't even think about it until right as I saw the brush coming in. Went with a shorty after that as I don't really listen to AM/FM anyway. Wish I could find a decent looking delete kit, but most just look uglier than a low profile antenna.
