Ok here is my problem, I have an 07 FJ, I did the a-trac/locker hack/ via a direct 12v. wire from the fuse box, this has worked flawlessly for almost 2 years, suddenly the a-trac wouldn't work with the locker, I redid the hack, it worked once, now the a-trac doesn't work, the dealer said I need a new master cylinder sensor that you can only buy a complete master cylinder, $1,600.
I need to know from you tech guys if there is a way to bypass this so I can run both without spending $1,600.
any help would be great,
thanks,
Tom
thanks,
Tom
