Note: If you decide to attempt to do this modification yourself, and you make a mess of it, or it has deleterious effects, I cannot be held responsible. PROCEED AT YOUR OWN RISK!
Now on to the installation.
This guy 銀チタンstarted this thread http://www.fjcruiserforums.com/forums/engine-performance/143058-cng-conversion-alternative.html#post2101736, and it got me interested in the subject. I began researching cng fuel systems to keep up with the thread, and I had expected that the whole concept was based on hype, or had an Aquilles heel that wasn't immediately apparent. Instead my research revealed that the concept actually has merit, and can make economic sense, assuming that you have a way to regularly refuel your vehicle.
Here is what I discovered.
* CNG (compressed natural gas) is low carbon/low soot and does not blacken oil. This means a longer service interval, and less engine wear.
* CNG is naturally cleaner burning, resulting in low ash, and lowered nitrous compound emissions.
* Natural gas is produced domestically.
* The supply of natural gas, in the U.S. is growing daily.
* Natural gas is inexpensive compared to gasoline.
On this last point let's take a look at the economics of installing a cng system. These are my projected savings.
I use 15 gallons of gasoline each week, and I currently pay $3.67 for each gallon.
15 gals/wk x $3.67 = $55/wk
$55 x 52 wk/yr = $2,860/yr, cost of gasoline.
I can buy CNG for $1.85 gge (gasoline gallon equivalent) however it is 10% less efficient than gasoline, so I need to add ten percent to the number of gallons that I use each week to account for this loss.
15 gals/wk x 1.10 (add 10%) = 16.5 gge, CNG needed per week.
16.5 gge/wk x $1.85/gge = $31/wk
$31 x 52 wks/yr = $1,612/yr, cost of CNG.
Cost of Gasoline per year = $2,860
Cost of CNG per year = $1612
Diffence $1,248 (savings/yr)
Given these economic realities I determined that installing a cng fuel system on my FJ could make economic sense.
Let's use the numbers generated above to establish a target budget.
I intend to keep my FJ for five years and I would like the cng system to have payed for itself in half that time, or 2 1/2 years.
Rate of payback = $1,248 (savings/yr) x 2 1/2 years = $3,120
$3,120 is the target budget for installing the cng system, and I believe that this is possible if I do most, if not all of the work myself.
Let's consider the practical issues associated with automotive cng fuel systems.
There are three main issues related to installing, and operating on compressed natural gas (CNG).
First; is finding a CNG system that will work on the FJ.
CNG systems are not commonly installed on imported vehicles so finding one that is compatible with the SFI (sequential fuel injection) system used on the FJ does require some research.
Second; The cylinders used to store the compressed natural gas, are either heavy, and moderately expensive or lighter in weight, and incredibly expensive. Also each cylinder has an expiration date, and cannot be re-certified.:huh:
The availability of used cylinders for sale in the aftermarket is limited, and buying used tanks is risky, but the risk can be mitigated by buying from a reputable dealer, and/or having the tank inspected before purchasing.
Third; is the availability of refueling points.
Refueling points are critical to being able to take full advantage of the savings afforded by operating on CNG. In my particular instance there is a public cng station about six miles away.
Find refueling stations here - Alternative Fueling Station Locator
I should mention that there are also home refueling stations available that can compress the natural gas that is delivered to your home.
Now I will begin the installation of my CNG system.
To begin this installation I had to decide what configuration of storage cylinder(s) I would need. I decided for practical reasons to mount the cylinders on the exterior of the vehicle.
The frame of the FJ is a fully boxed, fully wrapped design, and because the spare tire mounts to the rear door, there is an open area under the rear of the vehicle that is well protected on the sides, and rear by the frame. This became the logical place to mount the cylinders.
I located a set of used cylinders in the proper configuration and order them from a reputable dealer in Utah. While waiting for the cylinders to arrive I installed a block heater. This will give me the ability to preheat the engine. The reducer requires a flow of warm coolant in order to operate properly and preheating the engine on chilly mornings will allow me to begin operating on CNG sooner, saving gasoline, reducing cold engine wear, and providing cabin heat sooner - http://www.fjcruiserforums.com/forums/engine-performance/143817-how-install-circulating-block-heater-2010-2012-fj-cruiser.html
The cylinders arrived by truck. There are two cylinders in this pack, and each holds 3.5 gge, for a total of seven gge @ 3,600 psi.
EDIT: The tanks are actually much more limited in capacity. They actually hold only 2 gge each for a total of 4 gge @ 3,600 psi.
These are type II cylinders and have five years remaining before the expiration date. These cylinders were a good compromise between weight, price, and useful service life. The cylinder pack weighs 150 lbs empty (200 lbs full), and I paid $550 for it, plus an additional $130 for shipping.
So far I have spent $680 of the $3,120 budgeted for this project ($3,120 - $680 = $2,440 budget remaining).
Here are pics of the cylinders, and the 14 ga. steel shield that came with it.
^^^DOT certification (@ left) is important if you intend to install the cylinders in a vehicle.
The project this weekend is to fabricate brackets that will serve to mount the cylinder pack to the frame of the FJ.
I went to my local scrap metal dealer yesterday and bought a few pieces of steel. I payed 25 cents a pound, and the total was $10 ($2,440 - $10 = $2,430 budget remaining).
Today I cut, fit, and ground the pieces needed for the center support bracket.
I had the pieces welded together and paid the welder $40. I also spent $10 on grade 8, bolts, nuts, and washers ($2,430 - $50 = $2,390 budget remaining).
"The regulations for tank brackets are here: NFPA52 6.3.4 “the fuel container rack shall be able to withstand the force… in 6 directions up to…. 6 times the weight of the container when full"
Source: http://www.younkincng.com/ "Jim's CNG Install Manual"
The cylinders I am installing weigh 200 lbs when full, and six times that number equals 1,200 lbs. I designed the brackets to support a minimum of 1,200 lbs.
^^^ 7/16" grade 8 bolt and washer.
