How’s it going everyone? I know this is going to be another brake thread but I cannot find the answer to my problem.
I week ago I installed the “4Runner big brake” mod. I purchased 2 4Runner Gen 5 slotted StopTech rotors and 2 4Runner Gen 5 Power Stop Performance front calipers and EBC Green Stuff 6000 pads for the front and rear. My rear rotors and calipers are OEM. I also have Man-a-Fre SS brake lines which were installed 3 months ago.
Here are my symptoms:
- Soft brake pedal. A spongy feel would be the best way to describe it. If I press on pedal hard enough I can push it to the floor. If I pump the pedal my brakes become a little more responsive. My rig stops fine and I don’t feel like I’m in danger when driving. I just know something is not right and that my brakes should be MUCH more responsive.
- When going 20-30mph I feel a slight drag when I’m not accelerating. It almost feels like the pads are rubbing against my rotors slightly.
Here are things I’ve checked:
1) Bleed brakes, topped off the master cylinder with basic DOT 3 fluid which resulted in marginally better braking but it's still spongy. I used the poor mans method of a bottle and clear tubing.
2) Checked for leaks in all the brake lines (the ones I could access).
3) Checked and re-torqued the CV axle nut to 175ft/lbs.
4) Checked and re-torqued front caliper bolts to 91ft/lbs and rear bolts to 65ft/lbs.
5) Checked for any leaks in the master cylinder.
6) Did a zero point calibration.
7) I Checked all my caliper pistons and none seem to frozen.
I’m sure I have a few more things to check but for the time being does anyone know what’s going on with my brakes?
