Use the B12 rear springs which are meant to match the fronts and only add 0.9" or buy another spring set like Eibach that are matched and use their shocks.
www.bilstein.com
IMO it's best to use what has been tested and balanced for your truck otherwise you can get weird behavior.
The differential drop spacers reduce the angles on your CV shafts so that they don't wear out and snap while your on the trail. As you lift the IFS differential the angles on the shafts increase and will cause premature axle failure. Kits are cheap and easy to install.
While your fitting rear springs this is a good time to look at your rear control arm bushings. Make sure they are not torn. If they are OK and the new springs are installed drive the truck around the block a few times. With the wheels on the ground torque the bushing bolts to spec. They need to be tight. Once you do get all the work done take the truck in for alignment at a real 4x4 truck shop. Don't wait on this. Alignment numbers should look like this:
Do I need the diff drop spacers if I’m just raising the rig by 2”?
looked at those springs...it’s confusing when they don’t list the FJ as a recommended fit:
Bilstein B12 (Special) For 2010-2020 Toyota 4Runner 1.5" Rear Coil Springs
The Dif drop kit is only $50.00 and takes 30 minutes to install. It depends on how long you want your axles to last.
Use the search engine on the Bilstein WEB site:
B12 (Special) - Suspension Kit
Available From Your Local Dealer
Part Number:36-281817
Product Type:Suspension Kit
Position:Rear
MSRP:$249.00
Notes:
-Rear Lift Height: 0.9"
Product Description
Bilstein B12 (Special) suspension kits are designed to alter the vehicles ride height for optimum performance. Utilizing various different technologies to achieve the optimum ride height for a specific requirement. Bilstein B12 (Special) suspension kits provide the perfect combination of suspension dynamics, quality and aesthetics.
Buyers Guide
Toyota 4Runner 2020-2003, FJ Cruiser 2014-2007
https://cart.bilsteinus.com/details...47056532308851991&Submodel=6231015219844690056&Pos=Front&Dr=4893330155885314595
