Hi all
I have a 2008 Automatic FJ with 208,xxx miles. I've had it since around 150,000. Done a lot of maintenance myself. This vehicle has been awesome, but the last owner didn't treat it super well. I've fixed a lot of problems left over from them. I've kept it alive and really enjoyed owning an FJ. I don't think I'm going to get too much more life out of it, but I wanna make it last at least another 6 months or so, so that I can get either a new 4Runner or Tacoma.
Here's my issue. Around 200,000 miles, I started to experience some pretty noticeable engine shudder. I ignored it for a while, but my wife would complain about it. When changing gears, the engine would "shudder", vibrate, shake. It would stop after a few seconds but sometimes it was harsh enough that you'd think "jeez".
I began to look into how to address this. Thought maybe I should change tranny fluid. Was informed by many people "don't do that, it's got 200k miles, bad idea." I looked into this a lot and read some posts here, as well as saw some videos, of people who used Lucas Transmission Fix, an additive, to fix this problem. I had previously used a Lucas Additive in my oil that seemed to work good so decided to try it after doing some research.
Bought it, added it to tranny fluid. Not a huge difference at first, thought it would need time to work it's way in. Then suddenly- boom, shudder gone. Tranny was shifting smooth, wife was happy, I felt proud of myself.
Well now, I have a new issue. A few weeks ago, I was on the highway accelerating up a hill, when I felt the car seemingly slip out of gear. RPMs shot up while speed remained the same, and I was like "wtf was that?"
After that, the transmission seemed to be having trouble with shifting. If I try to shift to quickly, like accelerate from a stop really fast, it will hang up, take a second, and then suddenly very harshly BOOM pop in to gear and throw me forward a bit. Sometimes when cruising on highway, I could feel it struggle to change. Other times it's fine. When I first start the car it seems ok, seems to happen more once it's warmed up. I noticed if I take it slower, it'll do ok.
Then the christmas tree lit up. I've had this happen before, I know it's standard, and I have a reader. So I take a look at the code and I get the following:
Code P2714
Pressure Control Solenoid D
Perfomance / Stuck Off
So I being to look into this. I'm seeing a lot of different solutions. Some say this can happen if you don't have enough tranny fluid. Some say it can happen if you have too much. Some say you just need to replace the SLT and SLU Solenoid. Some say to do just a small drain and fill of the fluid. I think I have some idea's about what I should do, but I'd love to hear some ideas or feedback before I proceed. I wanna tread carefully. It's an old car with a lot of miles, and I wanna make it last at least another 6 months or more, but I will also probably put another 10-15,000 miles on it in that time as I do a decent amount of driving for work, and need it to be reliable until I can afford to upgrade. I love my FJ, but it is nearing the end of its life with me as I need to move to something newer. Any advice is appreciated and I will respond. Thank you!
Code P2714
