tire pressure light
2.6K views 4 replies 4 participants last post by  !Cruzer!
#1 ·
i've setup a second set of wheels and tires for running the trails, wheels are an extra set of oem alloys which i did'nt get the toyota tire pressure valves with ,my question to the forum is does anyone know how to shut off the low pressure light since i do not have those valves in Fred
#5 ·
if you want to be able to turn the light on/off depending on what tyres you are running this is what you would do.
1.Get a 'add a fuse' from Napa etc, plug it into a IGN hot fuse spot in the interior fuse block.
2. Run the wire from the add a fuse to a switch
3. Run a wire from the other side of the switch and splice it into the pin/black wire (a32) as described in the above link.
When you want the TPMS light on, turn the switch off and it will function normally... TPMS light off, switch on and 12v will be applied, turning the TPMS light off.
