Do you use anti-seize on your spark plugs?
Love to hear about why or why not and the different theories out there.
Also let me know what plugs you use (OEM? Iridium?) and what brand anti-seize do you use (if you use it)
Use anti seize compound? Always in aluminum-head engines.
I've been using anti-seize on plug threads for 50+ years, probably the greatest number of plugs changed were on air-cooled 2-stroke motorcycle racing engines that typically ran very hot, and had plugs changed very frequently.
Caution is required so no anti-seize ever gets near the ceramic electrode insulator or the body insulator ... that means no smearing anti seize on the plug threads with a finger, and subsequently getting anti-seize transferred to ceramic surfaces.
I use a small 'acid brush' with bristles trimmed to about 1/4" to apply the material, only a tiny amount (grain of rice) worked into the thread roots with the brush, no blobs or globs visible on the threads, just a microscopically thin film.
Probably used more Never-Seez brand than all other brands combined, but had many different options to play with, moly disulfide, nickel, copper, and titanium disulfide fillers. Never saw much difference in performance, at least in spark plug applications.
Always reduced installation torque by ~15%
I've always used either NGK or Denso plugs for ALL applications, platinum or (later) iridium electrodes for all Toyota applications. For many years Toyota Owner's Manuals gave part numbers for both NGK and Denso plugs, but switched to recommending Denso only after about 2010, even though NGK listed 'equivalent' plugs with same heat range, etc.
(For many years, Toyota installed NGK plugs in one cylinder head, and Denso plugs in the opposite side from the factory on V6 engines. Not sure if the same practice was followed with the V8 engines.)
