No, you should never use anti-seize on spark plugs! Heres why:
- It acts as an insulator affecting the total electrical conductivity of the spark plug. This is the opposite of the desired purpose of a spark plug
Absolutely untrue, and can be easily proven by making some simple measurements with an ohmmeter or even a milliohmmeter if you are interested in looking for hundredths of an ohm.
Just for the sake of argument, let's say that the anti-seize introduced 0.1 ohm of resistance, or 1.0 ohms, or even 10 ohms of resistance in the secondary (spark) circuit. Given that the plugs used in almost all modern IC automotive engines have internal resistor value of around 5,000 ohms, do you think that a resistance of 5,000.1 ohms will make any detectable difference in engine operation, or spark energy, compared to a resistance of 5,000 ohms?
How about 5,001 Ohms, or 5,010 Ohms?
And remember that the a plug's resistance tolerance is typically +/- 10% or greater, so a brand new plug can have a resistance of anywhere between 4K and 6K ohms.
