Has anyone tapped into the under dash fuse panel to add other circuits?
If so, how did that go?
I'm wondering if it is worth the time and trouble to try to get that sucker out to see if the unused fuse locations can be used for some added circuits.
I know I can always added another fuse block and bring another run in from under the hood, but it would be cleaner to just use that panel, assuming that there is enough current available and there is an easy way to tap it...
Thanks in advance for any wisdom
