avic-d3 just got here!
2.7K views 14 replies 10 participants last post by  selectpet
#1 ·
so i just got my avic-d3 and researching some stuff before i install it. i noticed on a few eclipse installs a trim kit was needed to fill in the gap on the left and right. does anyone know if this is needed for the avic-d3, if so or if no one knows where can that b purchased? thanks fellas.
#3 ·
#6 ·
All standard Double din receivers/stereos require an adapter since toyota uses a non standard sized opening. there are two routes you can take. Metra has these wings that attach to the oem brackets that fill the side. Then there is schosche (sp?) that is all plastic and replaces the brackets but encircle the whole stereo (fills in the sides and a small strip on top/bottom).
Wish someone would come out with a replacement central panel that makes the stereo opening standard size and more factory.
T
#8 ·
You can always call the guys doing the Group Buy on the AvicD3 and get it pretty quick and probably cheap too.... The AVIC D3 GroupBuy thread is pretty active....check it out.
#11 ·
got pics of the unit
