So I have 4 KC HiLites 100W off road lights that I would like to wire into a single switch.
I plan to run the wires from the lights, under the roof channel trim, down the windshield pillar (under the outside fascia) and into the engine compartment to relays and then from the relays into a single switch.
with the limited amount of space under the roof channel trim, I am thinking of daisy chaining two lights together, so instead of 8 wires running on the trim, I will have 4 wires.
So basically wire the two right hand side lights together (4 wires into 2) and the two left side lights together (4 into 2) and then run those 4 wires under the trim, down the pillar and into the engine compartment. Then run two relays (one for each set of lights), then from there, bring them together and into the stock off-road switch from Toyota (I found the wiring diagram for that switch, so that part shouldn't be an issue).
Is this a recommended way to run 4 lights, or should I just run all 8 wires down to the relays?
