Hey! That is nice. Was it completely flat behind that panel (i.e. no ribs)? It looks like you could mount up two:Scott9000 said:Still working on the wiring but I think it turned out nice.
Scott,Scott9000 said:I just checked it's white with blue stripe. And no I tested it with the sub switch in the off position - lite up the tester.
There are 2 20A fuses for the stereo #17 & 27. So I'd assume one 20A was for the sub. Manual pages 321-322bigbill25 said:Scott,
Great info! How big is that wire? 12ga? 18ga? 24ga? Wondering how much current it can handle. I wonder what fuse it goes through?
--Bill
Is their a ground point back there or did you use the ground on the harness or tap a screw into the abundant metal around the wheel well?Scott9000 said:I used the outlet I installed in the rear (spliced into the sub constant power) for an entire week with my ARB fridge plugged in. No problems and no blown fuses.
