41 - 60 of 123 Posts
Discussion starter · #41 ·
Update: Driven about 75 miles so far and no codes, lights, noises, and runs great. I removed valve covers once again and timing marks are dead on. The accumulated stretch seems to be nearing the adjusters limits and imagine chain replacement is sometime in the future. All good for now.
This has been a very interesting thread to read. I`m stunned at the amount of sludge in that engine. What a project.
Discussion starter · #43 · (Edited)
The below picture shows some effect of running ATF in your engine. Oil Control Valve pictured to the left (drivers side valve) was replaced after the OCV pictured on the right (passenger side). I ordered on Ebay and received at different times. Neither replacement had an effect on error codes or performance. What I noticed is how much reside was removed by SeaFoam and ATF. I ran a half tank of gas, about 75 miles more on the left/drivers OCV before replacing.
I've done the final sacrificial oil change and got very little sludge from the drain plug with ramp under passenger side wheel (to angle sludge towards hole and away from pick up tube filter in pan).
The screw driver is a medium sized with most of the sludge amount to just a pinch of debris. I did not drop the pan and will not until next oil change which probably won't be by me as I will be Swapping in a V8 or selling on with full disclosure to new buyer cheap.
It is running great with no odd sounds. Power is good. Exhaust note is Snorky with the snorkel and TRD intake.
Very educational post! Thanks much for your research and notes.
I doubt that I'd ever go through the amount of effort that you expended, as if I experienced the same timing issues I'd just go with the full chain and tensioner replacement and be done with it.
But knowing how all of it works (and the purpose of all of the intricate interaction of the parts) was really good to know. Thanks again for your diligence, and I look forward hearing about your 4.7 build!
wow if anything this thread illustrates WHY to keep your oil changes every 5000 miles , I had engine problems this past spring with the timing chain cover leaking antifreeze , it wasn't an easy teardown but while were were that deep in the engine we decided to replace the timing chains , the engine had 100,000 miles on it and was drastically cleaner than the one in this thread, here is a pic of mine
Zunami -
The only question I have about your "skipped tooth/chain stretch" hypothesis is that you are using the external timing marks on the crank vibration damper as your crank timing reference mark, rather than the internal timing marks on the crank sprocket. Being a bonded-rubber damper, there is always a very slight chance that the external timing mark might not correspond with the internal timing mark if there has been any "slippage" in the damper because of rubber bond failure.
However, I am not aware of any reports of separation problems with the 1GR-FE damper.
I do have a cam chain removed from an engine that exhibited the P0016 DTC, and the DTC was corrected when the chain was replaced. (I don't recall if the VVT actuators were also replaced.) I haven't had a chance yet to measure link-to-link "clearance", and after measurement I will separate the chain at several locations to measure pin and bushing wear, look for galling, etc.
A quick look at the chain after solvent-cleaning to remove all oil didn't seem to indicate a chain with excessive pin-bushing clearance.
I'm hoping to tear into my VVT-i actuator problem in the next 2 weeks, so I'm currently ordering parts.
Can you guys who have pulled the timing cover share some advice on sacrificial parts please?
I'm going through the manual and parts diagrams... looks like I need 2 types of seal packing (though one type may be optional for the water pump), a cylinder head o-ring seal, a timing cover gasket... anything else?
While I am in there, I plan to do the water pump.
I'm at 135,000km... should I replace the timing chain? Oil pump? While I have it apart I tend to lean towards doing everything that is accessible, but this may very well be overkill.
Thanks in advance.
The tensioner by itself can be inspected easily by just removing the inspection cover, 4 easily removed 10 mm bolts on front. You need a mirror or scope to get a good view. Remove and replace could be done too but I would be hesitant to try without the valve cover off. Again recommend valve cover removal.
Are you saying the chain tensioner can be R & R'd thru the inspection hole?
DEWFPO
Discussion starter · #51 ·
DEWFPO
I wouldn't. You need visual perspective from the top. Valve cover needs to come off to replace witout risking a fatal bolt drop down the cover. Though I think you could, it is just Easy enough to get the cover off. Plus you get a good look at things.
Thanks ZUNAMI1,
I am still trying to diagnose the source of a rapping noise on cold startup that started a few days ago and lasts several minutes on cold start up. It actually sounds like a chain hitting the inside of the motor and is random rather than rhythmic. It disappears when hot and is not present on warm or cool startups.
It 'sounds' like it's coming from the passenger's side of the motor near the inspection cover. I used a mechanic's stethoscope to dry to nail down the noise but haven't been successful.
I always use M1 or Amsoil oils and filters, I have no reason to believe the engine is sludged up. I am the original owner and the mileage just turned 109,000. I do not drive the engine hard or abuse it.
I have been using 0W40 oil and last night I changed it to 0W30 and it made no difference on cold startup this morning other than the rapping chain sound seems more rhythmic now rather than random.
The engine runs great, like new and there are no warning lights.
I don't have an easy way to get a sound clip to post and I haven't found any online that sound like mine.
I appreciate this thread, your write-up and your opinions.
DEWFPO
Thanks in advance.
It sounds like your going after the timing chain. Would it be too much to ask for you to document this R & R as best you can?
Thanks, DEWFPO
Thanks, DEWFPO
I'd be happy to, but I decided I would be better off financially and "environmentally" to put this off until May.
With the lift and roof rack, my FJ doesn't fit in the garage, so I'd be doing this outside right now, and it's below freezing out there. No thanks!
Discussion starter · #55 ·
My engine is running great and I just did some towing. The noise I heard before could be described a chain interference bit it actually got worse with warm up. Mine was oil starving.
I think Iit is very possible the tensioner ratcheting type stay is not catching and therefor leaking down after shut off creating a loose and loud chain at startup. If your chain is so slack the tensioner stay may be on the last tooth and is holding but shy of proper extension resulting in slightly lose chain. The oil pressure would come up to push the tensioner rod beyond the last stay notch.
It wouldn't take much to gum the tensioner up an have your symptoms.
I think you could solve it through the inspection cover with pre start inspection and immediate post running inspection making note of the precise position of the extension rod. The adjustment notches a quite fine and you shouldn't note any significant change in extension.
As well, the precise nature of the latching mechanism is why I believe it may be prone to failing.
If the spring hasn't failed in the tensioner I would guess an in place cleaning would solve it. Spray carburetor or brake cleaner on it and/or do the atf add to your oil. Don't be shy about it. The additives won't hurt oil performance in any significant way. Feel wrong but necessary.
Run the atf for up to a tank of light driving.
Does the inspection cover need a new gasket after being removed or can it be reused? Need any gasket sealer as well?
Here's a sound clip of the sound my engine is making. It's louder in person than on this clip. It started out as a random rap when cold, now it sounds rhythmic to me. The sound disappears within a few minutes.
http://vid99.photobucket.com/albums/l304/dewfpo/Cold Start Rap_zpsyl88qegl.mp4
Thanks for the comments. DEWFPO
Discussion starter · #57 ·
Thanks for the comments. DEWFPO[/
QUOTE]
No gasket or sealants required.
Sounds like the adjuster to me. The timing plate on the front or no oil in adjuster. But get the valve cover off and maybe you can see cam and cam bearing condition too.
Does it go away at higher rpms?
It does not go away with higher rpm. It does disappear as it warms up. The sound clip is a cold start ~63F and the starting rpm is ~ 1,250. Revving it up to 2,000 rpm (cold start) does not change the sound of the rap, only the speed.
I'll pull the inspection plate in the next day or two and post what I find.
DEWFPO
I removed the Timing Chain Cover Plate on the front of the passenger's side of the engine to expose the Primary No.1 tensioner for the Timing Chain.
The plunger is VERY tight against the nylon guide and I was not able rotate the Stopper Plate on the adjuster no matter what I did. I tried prying the guide against the plunger to compress it back into the tensioner and I could not get it to budge at all. I thought I might be able to move it enough so that I could rotate the Stopper Plate but no joy.
After six hours it maintained it's tension so I don't think that it is the problem. I searched the internet high an low and it doesn't seem that anyone, anywhere has ever replaced one on a Toyota 1GR-FE engine (Tacoma, FJC or Tundra). The tensioner does not appear to be controlled by oil pressure at all. The tension must be completely regulated by an internal spring.
If I assume the chain is good, and that is a pure assumption, then the VVT-i Oil Control Valve must be the culprit.
DEWFPO
