troubleshoot and doubleshoot!
806 views 4 replies 3 participants last post by  Briman42487
#1 ·
I just upgraded my speakers but still have my stock face. I went with 6.5's, tweets and 3.5's up front.
When I turn it up past about 40 (60 is the max rating) it starts to sound like the speakers are blown, just a lot of distortion but at low levels its super crisp.
Now the stock speaker wires in the door are blue and the other is red with a strip. I dont know which one is positive and which one is negative. The wires in the dash for the 3.5's are black and red.
My guess is that I have a wire switched somewhere? Suggestions?
#3 ·
even if you had a wire switched, you will notice a lack of bass, not distortion. homeboy nailed it. lack of power. you are pushing your system past its capabilites. the amplifier in your stock headunit is being push beyond a clean signal. thats as long as i really want to go unless you are dying to know more. let me know if you have any further questions or problems.
#5 ·
with stuff like you are running now, it just sounds bad. when you start reaching a speakers limits heat and power wise, clipping a signal can do major damage. i run 2200 watts rms on a pair of woofers that calls for 400-500 rms each, no issues. and i absolutely rail on them. i ran a pair of 500 watt amps on a pair of woofers that called for 750 rms each (in a sealed box, not nearly as tempermental distortion wise) and i killed so many pairs.
underpowering generally ends up clipping the signal because you arent getting the performance you want so you push it harder, past its limits.
i can still force my high end alpine and zapco EQ to clip.
