21 - 40 of 41 Posts
In little ol Nova Scotia we are less than 70km at any point from either the Atlantic Ocean, Bay of Fundy or Northumberland Straight. So to say vehicles rust here is an understatement, the moment steel is manufactured and meets oxygen it begins to break down. Painting and coatings are just a prolonging measure which certainly help but in the end it all rusts.
I once knew an old engineer who owned a ford bronco (not the full size) and every year he took it apart bolt by bolt until it was just a frame sitting in his shop. Now 20+ years after purchasing the Bronco it looked like it had just left the showroom floor. The point is if you have the time once a year to strip your vehicle and put it back together I'm sure you can stay ahead of the rust. Otherwise do what you can to keep it at bay and enjoy your rig.
Cheers
I am trying something new with my FJC, spraying everything underneath with WD40 two or three times a year. I have seen metal coating weathering tests and WD40 does pretty good in preventing rust. Buy the Big Blast can and it doesn't take long.
WD-40 Multi-Use Product Big Blast Can - Cover Wide Areas Fast!
Reactions: WaJohnZ
Where possible, which isn't much.
Well my 07 FJ is real rusty underneath after 8 winters.
So I look under my wife`s 2010 RAV4 with 20k miles guess what.
It`s really rusted as well!!!
What gives.
Can you really keep rust at bay, I say nope....
I had 2001 tacome . And there was a big problem with frame rust .so I usually had it sprayed with 3m rubberized rust protection. So when I got my fj didn't want to take the risk . Even though it was clean I sprayed the 3m staff on the main frame. Be carefull when spraying it. It is rubberized so avoid spraying on fuel , electric lines and bolts. Stick to the frame as much as possible. And under wash frequently in winter.
When I started looking for my FJC, I was looking for an 07 TRD. Being on the west coast, rust wasn't really a factor unless the car spent a lot of time near the coast. I saw that spent a couple years( at least on carfax reports) in snowy or humid areas and they were rusted out. I couldn't imagine replacing the shocks let alone what it would take for other, more critical repairs.
Anything you can do now, to reduce the need for further repairs in the future, should be a priority.
It depends on what your over all objective is as to whether you want to rust proof.
I bought a '86 F150 about 10 years ago and it had been garaged and only had 17K on it.
There was no rust.
I had it repainted the original color and rust proofed.
I painted it because to old gentleman who owned it since new did not wash the bird dropping off so the paint was stained.
Today the truck looks and drives like it is 5 years old.
I undercoated my two FJ's at Ziebart when new, take them in every year for a touch up, my objective is to keep them like new, as much as I can while still driving them in the MD weather.
My first FJ, a 2007 TRDSE, I rattle caned it very year with Rustoleum paint.
That worked but it was a large time eater.
My $02…..gm
There was no rust.
My $02…..gm
Will ziebart do a vehicle that already has rust?
I think you should neutralize it somehow or the rust will continue under the undercoat.
They will undercoat older cars, the cleaner you get it the better the result.
You take it back every year and they freshen it up!
Better job than I can do!…..gm
Being from Wisconsin, I have a friend who has a 2007 FJC and he has almost no surface rust under the vehicle, which was observed while replacing a heat shield which had fallen off due to corrosion around the fastener washers. So we removed all the heat shields cleaned the stud threads and replaced all the fasteners with addition fender washers. We used SS fasteners and anti-seize on all the threads. I'm always amazed how those heat shields come off the same way on so many vehicles!
I live on the west coast where rust isn't a problem but I grew up in Iowa where cars rusted thru in a few years. Back then we used to take a 2-5 gallon garden sprayer, fill it with used engine oil, and sprayed the underside everywhere we could reach. This pretty well eliminated the rust if done once or twice a year. Not very environmentally sound and really messy but it worked. WD 40 sounds better. I also remember a lot of smoke as the oil burned off the exhaust system but it was the old days.
siskiyou2
Thanks you guys! The reassurances were very helpful. I'm now proud to be an official owner of a 2010 Iceberg White FJ!!!
Edit** This is for WaJohnz and FJ Cruiser Matt!
I have a 2010 Iceberg as well!
Glad the Canadians could put your heart at ease... We are pretty used to rust.. Lol
Post some pics!!!
Cheers
Hi - Can you tell me what you undercoat your FJ with? I live in NH and noticed extensive rust on vehicles for sale here. We went south to pick up my FJ and thought undercoating was a good idea. Any suggestions would be appreciated!
Cindy
21 - 40 of 41 Posts
