To read the original full thread and post questions/comments on this topic, please go to http://www.fjcruiserforums.com/foru...e-performance/70947-battery-light-possible-fix-your-alternator.html#post1149310
Well, I fixed my own alternator this morning.
After I left my house to go get coffee from the local WaWa, I had the battery symbol idiot light come on, really a erratic flashing, it seemed to be effected by the rpm range some too, and at some points, it would be steady on.
I looked at the voltmeter, and it was still in the charging range, but at the bat' light illuminated, the needle would dive just a tad. I pulled over and checked the bat' terminals and they were clean and tight, I also checked the stock bat' sight window, and it was blue, which means it was okay, too.
Now, I pulled ok the glove box manual for yucks, and the only thing they wrote under this light was to contact Toyota right away. This was a little worrisome to say the least. I am thinking that this could end up costing some bucks. My thoughts based on the the symptoms are that the alternator has gone bad in some way or the regulator was not distributing the power correctly.
I opened the hood and decided to do a small test to make sure my guess was right, so I took a can of brake cleaner, and sprayed though the openings in the alternator to see if it had any effect, and it did, the light went out in the dash, but soon came back on after 10 minutes, but it proved my theory.
Now being that I have used my FJ for offroading, I knew this wold not be covered by warranty due to the flash muddy water storms my FJ has seen, even if it was not related.
I did check on the price for a new alternator just for yucks $478.05, a tad bit pricey, But I don't want to just toss that cash out just yet, so I figured I would pull the alternator out and disect it a little, so below is the outcome.
First you need to remove the Alternator from the FJ. To do this, you need to remove the battery wires from the battery using a 10mm socket or wrench, then use the same for removing the battery hold downs, and then remove the battery itself along with the plastic tray. This needs to be done in order lift the alt' up through the opening.
Next, remove the two of the push pins holing part of the rubber flap in the wheel well, one pin in the shock tower, and one in the frame rail, so you can access a few of the wire harness bracket bolts.
Then using a 10mm socket to remove the two bolts from the side of the alt' and one at the side of the battery mount base, which will allow movement in the harness necessary for the alt' to have enough room to get through.
You will also need to remove the wire connections from the alt', one is a 4 wire connector, which you need to squeeze the tab with your finger to release it and then unplug it.
The second on has a gray round cover which snaps on, which can be removed by placing a small flat tip screw driver in one of the slots and pry slightly to release it, then use a 10mm socket to remove the nut holding the wire on.
You can see the connection point here below.
Next, using a 10mm socket, remove the engine top cover so you have room to get release to tensioner for the serp' belt.
Next, you will need to use a 14mm socket to release the tensioner for the serp' belt and remove the belt from the alt' pulley. In the picture below, you can see the belt stuffed forward near the fan area so you have room to work.
Now use the 14mm socket and remove the two bolts that hold the alt' in place, these are both accessed from the front of the alt area, one towards the bottom and one on top, again, you can see the two hole locations in the photo below.
Once the bolts are remove, you will need to move the alt' up and down and wiggle it in and out to get it free, and maybe use a pry bar between the engine and the alt, to pry outward a tad.
Once it's free, you can maneuver it upward and out.
(Continued in the next post . . . )
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
