That thread doesn't tell you much about that particular camshaft. 224 degrees, 3xx lift, what's the lobe center, overlap, etc?
I wonder if Crane, Crower, Lunati, and the like have any listings for Yotas. Personally, I rather do a custom grind to with ported heads/intake instead of your standard run of the mill camshaft.
I want to build up the engine first before adding a power adder. You see, you can't see ported heads, bigger valves, ported intake, cam (you could hear it though depending on the specs) and pistons.
