The MAF cleaning thread started moving towards a Throttle Body cleaning so I decided to go ahead and clean mine and take a couple of pics along the way. First off I dont live in a real dusty environment and I do run a K&N air filter that I clean every 5k. I have also started using the Lucas oil fuel treatment in every tank of gas to see if it worked and so far I think my mpg has gone up slightly.
First off here is a pic of the Throttle Body that is just under the palstic engine cover:
Loosen the screw that holds the clamp tight around the neck of the throttle body, its the one with the baby blue plastic clip. I also used my compressor to blow off any loose dust from the engine.
Then loosen one of the screws and remove the other screw that holds the intake in place and remove the intake from the throttle body:
This will expose the opening and butterfly in the throttle body. Note that the TB does not appear that dirty but you can see a bit of soot:
Take a shop towel or rag and place it under the TB opening and spray this stuff:
into the opening while working the butterfly with your fingers. You will notice some black stuff that naturally comes off and out onto the rag. Then carefull reach in and wipe out the inside of the intake working the butterfly, make sure you dont get your rag or shop towel stuck in the butterfly. This is what my shop towel looked like after the wipe:
Once you wipe out the inside put everything back together pretty quickly and start the FJ. It will hesitate at first but quickly even out. Take it for a spin around the block and to clear out the cleaner. Hope this helps.
