21 - 40 of 1,410 Posts
Re: A Fool and his Money: my FJ40 build
This is an FJ, so it rightly deserves it's own place in the build section. :)
Absolutely. And, what a build-up it's going to be!!
In spite of my frequent "purist" (and seemingly snobbish) attitudes towards not molesting vintage FJ's, in my opinion, you have selected the perfect (donor truck) candidate, as well as, the ideal elements, components and concept for an awesome FJ40 rock-crawler conversion. With that being said, and my perceived knowledge of your abilities, talents and a healthy affliction of OCD, I hereby grant you a special waiver to continue with this superb project. ;)
I will not only be following your build-up with extreme enthusiasm and cheering you on from 2150 miles away, but I also expect (request) to see your labor of love in-person the next time I'm out in AZ visiting the folks.
Good luck, Jon. (And, please let me know if I can be of any assistance from afar.) You're off to a perfect start, and keep the progress reports rolling in!! :bigthumb: :bigthumb:
Discussion starter · #25 ·
The saga continued today on multiple fronts.
I tried valiantly but in vain to make my milling/drilling machine mill some steel plate. It's way too flexy despite a few hours of attempted rigidification. (Yes, I *know* that's not a word, but the stupidity of trying to seriously do this is perfectly captured by the made up terminology!) In the end, I got to the point that I was doing a pretty darn good job with the plasma cutter and a well placed straight edge fastened down with a C-clamp.
The milling/drilling machine is still a reasonably precise drill press with calibrated ways, so I was able to get the hole pattern for the engine mounting plates right on the money.
I won't tell you how many parts I scrapped while getting the use of the plasma cutter dialed in!
The design of the engine mount is dirt simple. A number of examples of crawlers that I've seen (including Sean's, one at 4 Wheeler's Supply, and a well published build on Pirate4x4.com) all use the same principle. A plate is bolted to the side of the engine and a piece of (square or round) tube is welded to that, extending outward to the frame. At the frame end, the tube has a welded T-end with a urethane bushing in it. A bracket on the frame holds a bolt that goes through the bushing. Unlike the standard car-type mount where the weight of the engine is resting on rubber bumpers which sit on shelves inside the car frame, this design is equally strong right side up, upside down or laying sideways... a reassuring feature!
Added benefit - no-brainer build up! It's like tree house carpentry, but with metal.
The mounting points on the LS1 are an array of holes on the underside of the 45 degree outer surface of the "V" shaped engine block. The holes are evenly spaced and the dimensions are published in the manual. Once I cut and drilled 3/16" plate to size, I bolted it to the engine block and lowered it into position. I measured off the distance to the frame and picked an appropriate length for the legs of the mounting bracket system. I cut 2 six-inchers out of 2x2 3/16 wall tube.
The urethane bushings came as a weld-in bushing setup from 4Wheelers. They have 2 sizes. I chose the 1.75" tube version since I'm welding it into 2x2 square stock. If I'd gone with 1.5" tube, I'd have had to figure out what to do with the gaping holes on either side.
Next, I had to figure out how to nicely notch the heavy wall square tube.
I used to have a functional Harbor Freight Tools tubing notcher, but it didn't last very long. The principle was that a piece of tube could be held in the fixture while a drill drove an appropriately sized hole-saw into the metal in order to cut the appropriate profile notch.
Why not just put an appropriate sized hole saw in the milling/drilling machine? Sure!
Well, that worked about as well as the earlier milling effort. The hole saw bogged down, and when I went to a lower speed, the machine still flexed. When I cut slower, the chuck fell off it's taper... It was a total fiasco!
In frustration, I took the partially notched part over to the welding table and freehanded the notch with the plasma cutter...
Perfect! ...cleaned it up with the grinder and bevelled the edges. It was good to go.
The next one I just traced the shape of the circle with a sharpie and freehanded it with the plasma cutter. The first one cost me HOURS... the second one MINUTES.
Plasma cutters are COOL. :D
I tacked them together and beat them square before finalizing:
On other fronts, I got some frame reinforcing done (no pictures yet - to be appended to tomorrows batch of pics with the engine bolting in...) and I went to the yard where the body parts are sitting and got some measurements which were reassuring in terms of engine fitment.
I did a substantial amount of phone time regarding my need for a different front axle, and I figured out the clutch assembly, the transmision and the bellhousing which arrived in so many random crates with no diagrams or instructions... but lots of parts in baggies! I'm glad I spent the phone time, because I learned a lot. For example, I almost greased a no-grease pilot bushing, I almost UNNECCESSARILY replaced a part on the tranny with an equivalent one and I finally figured out what some of the rubber dohickies were for that came in my shipments.
I still haven't figured out what 2 steel rings are that came in one of the bags. They're slender material (2-3 millimeter cross section) and form circles about 3 or 4 inches in diameter... the proportions of O-rings, but they're metal. They look like they're made of rolled up thin stainless steel sheetmetal. If I can't figure them out, I guess I can give them to my girls and tell them that they're bracelets! :D
Keep it coming Jon. This is a build up-from the ground up!
Discussion starter · #27 ·
Ok... I've made some progress today.
I finally managed to sneeze some of the iron filings out of my nose! :D
Despite my best efforts at hand and face washing, though, I"m afraid my wife will discover that I've ruined the downstairs bathroom hand towel with black stuff that didn't come free with hand cleaner, soap and water.
I tossed it in the laundry... maybe it'll come clean and she'll never know.
Today, I committed to an engine position.
This has been a really big deal for a number of reasons.
First off, the tranny and the transfer case are really long, so the farther forward I go with engine/tranny/transfer case, the more room I have for a rear drive shaft. Also, if I'm not careful, the shifters are going to end up behind the driver's seat.
Unfortunately, too far forward, and there's no room for a radiator.
I bought a radiator that "goes" with the LS1 in the Chevy Camaro and Pontiac Firebird, but I'm having second thoughts about using it. That it's too wide, I can work with... that it's too TALL is going to be a bigger problem. If I fab notches in the frame deep enough to seat it FULLY behind the radiator panel, then it will basically be all the way through the front frame rail. I'm probably going to go cutsom on the radiator.
This means I have no idea how much room I need in front of the engine! I gave it as much as I could and said, "screw it... it's time to mount the engine."
This morning, I stitch welded together the halves of the riveted frame rails. The outer wall C-channel material is 3/16" and the inner wall C-channel material is 1/8" and fits inside the outer. Rivets on top and bottom fix them together. I wanted better distribution of support so I ran beads along the edges.
Although I had carefully wire-wheeled all the paint off of the OUTSIDE where I was going to weld, there was no way I could get between the plates and clear out the groove. I just had to suck that part up. Most of the welds went just fine, but occassionally I'd get into some snap crackle and pop that would splash weld metal back on me. OUCH!! When I flipped up my hood, I found that there were flames eminating from the groove ahead of my weld and dense gray smoke filled the garage.
I'm pretty sure I just carved about 2 years off the end of my life.
I looked over my work... some of it was ok, some of it was a little on the snotty looking side... overall not my best but plenty servicable. It was HARD to do the out-of-position welds on the BOTTOM edge of the frame.
Here was my nicest looking weld of the day:
Once done with stitch-welds, I proceeded on to the engine mounting project. I jockeyed the engine back and forth with the tape measure out, numerous times. I started to realize that I had NO FIRM GRASP on what straight, square or plumb meant in reference to the frame! I measured from the frame to the garage floor in several places and was reassured that the frame ran reasonably parallel to the floor as a starting point (plus or minus about a 1/16", actually... and within the warpage of the edges of the beaten, riveted, welded metal). I dropped a level on it and it was pretty close, side to side (bubble between the lines everywhere and centering it perfectly required less than an 1/8" of shimming everywhere I checked. That meant I could use the garage FLOOR as a measuring point.
I decided to fix the mounting points at a height relative to the ground. Since the frame was really really close to flat, the engine would be really really close to correctly aligned to the frame. I used the front cross member as a longitudinal reference point and picked a spot 18.5" back from there to mount to the frame. I marked the spots on both sides with a Sharpie pen and then used every T-square type tool I had to verify that the points where dead-on across from eachother and square to the frame. LUCKY for me, the frame rails run parallel through where the engine is supposed to be, while they flare out after that at some bastard angle that I have yet to determine.
My original plan had been to overlay a plate of 3/16" material over the inside aspect of the frame on both sides, where the mounts were going to lock in.
However, silly me... I made my MOUNTS TOO LONG for that! :mofo:
I had measured the space between the frame rails and I had worried that my welds might be less than perfect. I reasoned that the mounts that went on the engine would be largely put in tension and compression (relatively gentle forces on welds) while the mounting tabs on the frame would be placed in shear (a much more aggressive way to product-test the weld!). Therefore, I wanted to have the SHORTEST LEVER on the weld being put in shear and the longer lever could be given to the tension/compression part. I made the engine mounts long enough to get "close" to the frame rails so that my mounting tabs wouldn't have to stick out very far.
I got *REAL* close!
If the overall space between the frame rails is about 24.5" ... the width of my assembled engine+mounts is 24 and a quarter! There's no better than 1/8" clearance on either side.
Great! ... nice short tabs! :)
However, now I can't box in that part of the frame with 3/16" material to accept the engine mounts!
D'OH! :(
My choices, as I saw them, were:
1) scrap the mounts, modify or make new ones (fat chance!)
2) weld the tabs directly to the 1/8" inner wall material (yeahright!!)
3) use a gusset with a notch to accept the mount (too much fab work)
4) just cut out the inner wall and replace it with 3/16" mounted FLUSH.
Number 4 seemed the most plausible to me, plus I could use the plasma cutter some more!
I chose a segment of the inner wall of the frame which included 3 of the pre-existing cut-outs and I fashioned a mock up plate out of cardboard. As I did, I realized that had I not gone with this technique, I'd have been welding the 3/16" material ON TO the 1/8" material. I wouldn't have been able to weld it to the stronger stuff on the OUTSIDE of the frame, because the inner wall bulges too much (no - not like the FJC aprons ... it's just made that way).
I cut out the shape on both sides of the frame and then shaped two plates to fit inside. With a whole lot of cutting and grinding, they eventually inset nicely and sat flush. I tacked them down and welded them in place.
I brought the engine back in and repositioned it, only to find that I had wire-wheeled my marking points off when I cleaned up my welds!
D'OH! :cowsmile:
After figuring it ALL out again, I got the engine back into its intended position.
After reading as much as I could and calling a few people who know things not in books, I determined that the LS1 engine does NOT need to be mounted at an angle, although it will tolerate one. Some engines apparently benefit from a down-slant in order to get the oil sump to drain TOWARD the pump mechanism.
I figured that this engine is going to spend a LOT of time at odd angles anyhow, so that part doesn't matter.
What matters is that I'm battling with a really short rear driveline and the more pre-angle I can put on it, the less the CV joint will have to suffer through... but the more I down-angle it at the front, the lower the transfer case will end up being at the other end!
So I gave it a hair of down tilt, just for fun. I can't measure the angle with my tools, but I can guestimate by trigonometry and a bubble level that it's about TAN(0.125/19.5)=1.1 degrees.
Unfortunately, the front end of the frame RISES UP AND OVER the front axle. This isn't a flaw, but it is a challenge when I'm trying to figure out where and how to mount the tabs which will accept the engine mounts! Given where the engine ended up, the mounting had to be different in the front and back on each side.
I had bought a stack of 4 pre-made tabs when i was at 4 Wheeler's Supply (I also saw that they've premanufactured another bracket I'll need when it comes time for my disc brake conversion in the rear end! ... that's for later.) I had hoped that having premade tabs would save me some time. It did, but not much in the larger scheme of things.
Finalizing the tabs took a bit more effort, and then I tacked them in place using the engine and it's mounts hanging from the cherry picker as a template. I lifted the engine back out, tapped the tabs square to the frame with a hammer, and finalized the welds.
Here's what it looks like with my inset reinforcing panel and the mounting tabs in place:
Here's how the engine mounts go on the side of the V-8 engine block. Notice the black urethane insert that should let it wiggle a little:
Then I jockeyed the engine back in place and stabbed the bolt on the driver's side:
Unfortunately, the other side doesn't stab so cleanly. I could crush the frame together with a come-along and MAKE it stab, but that's the WRONG ANSWER! I don't want this under tension ALL THE time. I'm going to ream the 1/2" holes with a 9/16" bit and if it looks like I need more, I'll mount with washers between the fastener and the tab.
I'm not too worried about that since the ENGINE doesn't actually pull the car forward, it just TWISTS in place. The grade-8 bolt in the hole will only see shear force... no "out-pull" tension. If it did, I might worry about having a washer resisting the force.
I'm beat.
I was going to go back down there and assemble the clutch tonight, but I think I'll do that first thing in the morning!
Here's my FJC supervising my engine alignment:
You're making really good progress. How do you find time for work? :)
That engine is beautiful. The welds are are really nice too.
Lol! :D
Discussion starter · #29 ·
Lol! :D
I took this week off for nothing else but to get this project *really* started. There is going to be a lull in the activity after that till next month when I've got another week planned, which I hope will be dedicated to tearing down and starting to rebuild the rear axle. I'll be learning all about doing gears.
Thanks to my dutiful nature at work, I forgot to use my vacation this year... now I have to use it up really quick before January!
Better get cracking on this project. Can't keep us waiting for an entire month can you? :D. I know what you mean about vacation time. Better use it or lose it!
This is a fantastic buildup thread and your work is awesome. Thanks for the detailed write-ups and keep 'em coming. Undoubtedly subscribed.
Discussion starter · #33 ·
You're nuts! But this is a great read and you are also inspiring me to get off my ass and fix my rig! I blew the head on my '75 a couple of years ago and it's been parked in my garage ever since.:(
Consider a Chevy 350 engine swap to make a "Chevota". You could have fuel injection, more horsepower and less weight. There are lots of support sources for this maneuver. Downey Offroad's catalog is a GREAT source of info and parts.
This is going to be a fantastic trail rig. Can't wait to see what you have in mind for suspension and cage.
Discussion starter · #37 ·
Today was kind of a bummer.
It started out nicely. Linda got me a venti from starbucks while I lifted the engine out yet again, reamed the holes in the tabs with a 9/16" drill and dropped the engine back down. The bolts stabbed with ease and the engine came to rest... finally!
I can't take it completely off the cherry picker yet, because it's supposed to tripod on the transmission with it's crossmember support. Right now it only has two legs.
I cleaned up the garage in preparation for doing a nice clean clutch installation.
I had already screwed this up a little bit because I had already pulled the old flywheel off of the engine and when I noticed that there were two locator pins protruding from it, I dutifully flipped the thing over, found the backs of the holes and drove the pins out with a punch. I then tapped them into the identical holes in the new flywheel before bolting it on. When I test fit the clutch the other day, I found that it not only doesn't NEED the locator pins, but it CAN'T FIT with them in place. So.... I pulled the flywheel OFF again this morning and flipped it over to backdrive the pins again with a punch... but the holes don't go all the way through!! I tried grabbing them out with my Robo-grips but they're hardened steel and they just laugh at my pitiable attempts. I carefully ground them down flush with the flywheel... oh well!
According to the various sources of instruction I have (and they are ANNOYINGLY SCARCE) I had to replace the pilot bearing inside the end of the driveshaft. This is to be replaced by a part from Advance Adapters which is a bushing instead of a roller bearing, and helps to make up a length discrepancy between the parts.
I spent the greater part of the day trying to remove this bearing without violence. Then, when peaceful methods failed, I tried violence anyhow and was STILL defeated.
First, I pried... gently.
Then I tried to fashion a hooking tool to pull it out.
Then I tried the "hydraulic method" as recommended by the guy I called at Advance Adapters. He said "just pack the space with grease and find something that fits in the hole perfectly, then press in, and the grease will push the bearing out.
HA! ...yeahright.
I had a perfect fit. I pressed hard. I got jetted with pressurized grease.
Then, since I had some errands to run ANYWAYS, I incorporated a loop to Harbor Freight and got a pilot bearing puller. It was too big (I knew that when I looked at it, but figured it would be worth attempting to modify the tool for how cheap it was). I modified it and it still would't work (too soft - the metal mushed).
I called Sean, mostly for moral support... and vented.
He agreed that this must suck.
It did.
Then I went and tracked down a GOOD tool at NAPA Auto Parts... and when I finally got it, it took about 20 seconds to pull the bearing out.
Thanks to NASCAR out here on the west side, those two cross town errand runs cost me several hours in total!
By the time I was done, it was 4:30 in the afternoon!
One of the interesting things about HIGHLY modified 4x4's is that they're a motley collection of custom parts mixed with used JUNK. Nothing answers to a standard. On my FJ Cruiser, I can guess which metric wrench to grab for just by thinking for a split second about how strong the bolt must need to be. Toyota is VERY consistant. On my project rig, I'm mating a Chevy engine to a hybrid transmission made of mostly Dodge components with a Chevy input shaft. In between is an aftermarket clutch by Centerforce and a bellhousing and adapter kit by Advance Adapters. There is no unifying principle AT ALL.
Some of this is metric, some of it is not. Some connectors are screwing into aluminum and others are driven into iron. It's VERY confusing.
..especially for a beginner mechanic like me!!
So I called Advance Adapters... again... and ran through it AGAIN... and indeed I have to use this pilot bushing, and additionally, I should be using this previously un-noticed spacer that was in one of the parts bags. This spacer is designed to press-fit into the end of the crank shaft and go UNDER the pilot bushing.
So ... I began tapping the thing in.
I got it... mostly.
That's when it hit me.
*MY* NV4500 transmission is CUSTOMIZED!! It's mostly Dodge, but it's a little Chevy!! The input shaft is a Chevy/GM part! DO I NEED THE SPACER???
I called Advance Adapters *AGAIN* but it was after hours (1658 by my anal retentive time piece, but who's going to quibble about 2 minutes?)
:mofo:
I'll call in the morning. Hopefully they keep Saturday hours.
If I have to pull this spacer out, it's going to be an UNBELIEVABLE pain. I'll probably have to destroy it to get it gone. I may have to massage it away with a dremel.
I don't know which would be worse. Having to hammer the thing the rest of the way in will be no picnic either! It's pretty stuck, and it's not bottomed out yet!
I may still decide to kill this one and then get a fresh one, which I'll drop in liquid nitrogen for a few moments before tapping it in. Otherwise, I'm going to have to fashion a tool that will apply even pressure on the surface of the ring shaped spacer as I beat it with a sledge.
Here's a picture of my only tangible progress for the day, a fully mounted motor:
And here's a picture of the backside of the engine, flywheel removed, showing the end of the crankshaft. The hole in the middle is where I wrestled to get the bearing out and then got stuck at the next step!
Jon, as much as you agonize over your own follies, sleep with comfort that there are those who wishes we have the audacity to try what you are doing. Hurry up though, you're busy next month and we gotta get more of this while we can :D.
You are the MAN Jon!!!
The project is looking good, the motor mounts are great! They are a slightly better version (like 100% better) of mine that I had.
If I may, now that the motor is in its place I would gusset the top of the mounts on the motor (circled in yellow in the pic) especially on the passenger side, the LS1 is torquey on that one (motor shifts to passenger side under heavy acceleration)...
Also great choice on the CenterForce! They are some good clutches!
Also the oil connector that I have circled red in the pic, does it have a plug in it? this is perfect for a gauge:D
((sorry if you already mentioned some of this, had time to read most of it but not all, but I will!!))
GREAT WRITE UP BTW!!!
Call me when you need help with the wiring!!!
