361 - 378 of 378 Posts
Currently using 17" OEM wheels with 265/70r17. Switching to 285/65r17 on 17x9 wheels will not increase the overall tire+wheel size and the inward shift would only be 0.16" or 4mm. I assume this should not cause any problem and wouldn't require any modification or, am I wrong?
Currently using 17" OEM wheels with 265/70r17. Switching to 285/65r17 on 17x9 wheels will not increase the overall tire+wheel size and the inward shift would only be 0.16" or 4mm. I assume this should not cause nay problem and wouldn't require any modification or, am I wrong?
Checking the clearance you have now between the inner sidewall and the uca at straight ahead, full left and full right should tell you if they will fit. How come you don't want to go any taller? I didn't even know there was a 285/65-17...
owns 2008 Toyota FJ Cruiser
I do not do off-roading in any serious way so would rather keep the height as it is now. There are actually multiple tire options in that size.
Ok, I understand that. And I suppose there are; I'd just never looked, so I learned something today.
Hello everyone! New to FJ world and pretty new to forums. I am wanting a set of TRD Pro wheels. Wanting to know if the 16inch wheels that tacomas have will fit an 07 FJ. Wanting 16s so I can air down more on trials. Also the 17inch pro wheels are harder to find it seems in my area. Any help or comment would be appreciated.
I got the 16" bead lock style TRD rims from a Tacoma on my 08 FJ, no issues.
Hi All,
After reading the every page of this there doesn't seem to be much information around using 295/75/16 on the TRD 16x7.5 wheels (also checked the 16" wheel thread). It seems there are a lot of conversations around the 17" wheels and not the 16" when it comes to the 295, and there still seems to be a lot of debate on what is needed in regards to BMC or Spacers.
Little detail on my setup - 2007 FJ - Base - 4wd Auto - approximately 4" lift in front and 3" in rear - KSP forged aluminum UCA's. Vehicle is heavier than stock with Smittybilt M1 front and rear steel bumpers.
Now that my current tires are at end of life, looking to go from stock size up to 33". The BFG Ko3's, 295/75/16, seem to be the best AT for where I live (in the mountains). Was debating the 255/85/16 option but the one tire I would buy, given all the winter conditions, only has a "C" rating which is making me reconsider. I live on a rough dirt road and I imagine the wear with the extra weight would take its toll.
Question I want to pose, will a BMC be necessary with this size lift? Also, would spacers be needed? I don't really go off roading nor rock crawling. Just a daily driver.
current measurements with 265/75/16:
space at full turn between UCA & Tire: 1" - Assumption: will have .41" with 295's
space with wheel straight between UCA & Tire: 2" - Assumption: will have 1.41" with 295's
Closest point to the body mount when turning wheel: 2" - Assumption: will have 1.11" with 295's
Have you looked at the Toyo Open Country M/T in that 255? That's what I have currently and my last couple sets anyway. I love them. Tough as nails and they'll drive great even aired down if you need to go a ways before airing up again (not recommended but it happens). Off-Road Tires With Maximum Traction | Open Country M/T
I'm actually thinking of going to a C myself in an A/T next round but if those don't work out for any reason, it's those Toyos I'll go back to.
@Junior I'd definitely go for a M/T if I didn't live where I do. Those would not be capable on the switchbacks during the winter. In deep snow they'd be great, but the consistent hard pack I drive on, it would be a nightmare. This is why I will only go with an all season AT, the only two options I have really considered, based off size availability, are the Ko3's or Wildpeak at4w.
Reactions: Junior
Hi All,
I went from 295/75r16s to 255/85r16s. My rims are the stock ORP wheels so they are 7" wide compared to your 7.5" TRDs - so not much of a difference.
The 295s were General Grabbers (D) and I felt like I could never get them balanced really well. You WILL need a BMC...you 'can drive it' but wont be able to turn lock to lock. Since you have aftermarket UCAs, should be OK on that side - no spacers. Spare tire fits fine.
My 255s are Yokohama G003s (E)...I love them. They feel great and work great. I do have separate winter tires though. These are smooth as glass and seem to drive much better (for a MT). Theyll fit easily, and likely no BMC (I already had one). You will have to like the 'pizza cutter look' though - I dont mind them looking like tractor tires.
Hi All,
How big is the lift on your rig? Curious since I am at 4” in the front and believe the contact point would be slightly different negating a BMC.
Not if you have retained any suspension travel, in theory you probably have less clearance as you lose caster the higher you go!
But I am at or a hair under 3". Coilover front, Superflex springs out back. 1/2" body lift , but that doesnt matter.
Makes sense, thanks for the info @iwashmycar !
I'm currently looking at 2 sets of wheels that I really like both style and weight wise, for our camping rig. It has Goodyear Wrangler Duratec A/T tires in factory size, some aftermarket lighting, a Fuji rack, and an ironman RTT. Other than that, it is completely stock.
The wheels in question are:
Method 703
17x8.5 0 offset (backspacing 4.8)
Stealth Custom Series Blaze 10
17x8.5 -10 offset (backspacing 4.3)
Tires: Goodyear Wrangler Duratec A/T 265/70/R17
Is there anyone out there who can help me out with what kind of rubbing/fitment issues to expect? Again, suspension is OEM. No lift (for now), no aftermarket UCAs, no BMC, and no spacers used in this scenario. I saw a few people mention they ran a 17x8.5 -8 with 265/70/17 tires and had slight rubbing hence the reason for my uncertainty. A lot of manufactures are offering the 17x8.5's since the original creation of this thread. Many thanks in advance!!
Method 703
Obviously the et0 is a little better, but essentially the et-10 will stick out an extra ~1.5" compared to stock.
You are also adding an inch of wheel width so theyll look slightly more stretched onto the wheel.
With the stock tire size you should have no fitment issues. When you decide to get some 285's youll need a body mount chop is all.
I really want to move to 16's with 285x75r16 and have this opportunity locally on some Tacoma Rims. These rims should fit my FJ with no issues.... right?
"Set of 4 TRD Pro wheels from a 2021 Toyota Tacoma. Currently, they have 285/75-16 (33ish) Cooper tires. The tires are about done. "
I learned that the newer Toyota rims have larger lugs and won't work with older Toyota's. But I did find a great deal on some 2007, 16" rims off of a Tacoma. I already have the 33's mounted and they function wonderfully and look flilppin awesome.
