Help! Cv boot clamp broke, leaking grease
2 reading
19K views 12 replies 10 participants last post by  Geren8509
#1 ·
Anyone know where I can find a fix for a broken CV boot clamp? The smaller part of the boot is leaking a good amount of grease. Any suggestions? Can i go to autozone/pep boys or do I have to go to Toyota?
#2 ·
An eBay seller sells improved cv clamps that diminish boot leaks on lifted FJs. Search eBay for FJ Cruiser CV Axle Repair Clamps. muzzys_wholesale
#3 ·
Order one of those ^^^ in the mean time get a hose clamp with a screw tightner.
#5 ·
#7 ·
Go to a fastener shop that sells stainless steel cable ties. They come in various sizes and are very stout. The clamping portion is much thinner than a hose clamp. Get the installation tool. It looks like a screwdriver with no tip and a slot in the end. Just tighten and trim the excess. They aren't removable though. You have to cut them off.
#8 ·
The best worm gears are SILICONE EMBOSSED HOSE CLAMP NORMA TORRO- they are stainless steal and have rounded edges so no matter how hard you clamp- youll never cut into the CV boot and damage it. Thats what I use.
Sold on Ebay.
Larger- 90-110MM
Smaller- 25-40MM
#9 ·
Well it turns out the clamp was busted and the boot had ripped so my problem is no longer a $2 fix haha, but thanks anyway for all the help, I'll probably switch to those clamps once my rig gets out of the shop.
#10 ·
If they place the actual Toyota clamps- Id leave them- They should last a long time. Mine were replaced with the wrong ones (not Toyota ) and they looseded up which caused mud to get into the CV and killed it. Expensive loss
