How much heat is generated from a LED light bar? I know size will matter, but, how close to grill, bumper covers, or other plastic parts can they be mounted? How much air do they need so as not to over heat?
Thanks again for the info... The front bumper cover must be removed to install I am assuming? Ill try to go down to Toyota to grab some of the stupid plastic clips that I hear break every time you remove the bumpers...The diffused beam does not have a cutoff. That is one thing that fog lights have for a good reason. Light will shine up into the snow/fog and blind you. The fog lights can be aimed to the hight you like.
I asked them to chop my front grill because I had a set of lights behind it before, and they were a pain in the a$$ to clean.
To mount all my lights they just drilled and bolted them to the front frame horn. The round ones were mounted behind the grill while the duallys were sticking through. If you don't want to cut the grill, invest in a spray bottle. Even with the grill chopped, mine would be real hard to steal. They would spend a long time lying under my front bumper trying to unbolt everything. Or they would have to remove the bumper to get to the lights easily.
Calling Rigid is very high on my to-do list before ordering anything...Yeah, I get where you are coming from. They do cut out quite a bit of the output, but I like them better in fog an snow anyways. They take like 10 seconds to put on and take off, so I jut snap them on if it looks foggy. I have used Amber covers on my D2s an duallys, and I just find the beam patterns don't work. Maybe a set of D2 hyperspot aimed low could work well.
You might want to call rigid and ask them.
