Hi guys,
A question from down under... I have a 2008 120 series Toyota Prado 4L V6 auto which I believe shares many running gear components as the FJCruiser you guys have in the US.
I use the Prado primarily to tow a 2 ton tandem axle caravan (trailer?), and have had a Scangauge II ver 3.15 installed for some time now. This gives me a lot of good real time data, and helps make sure I don't get stranded out the back of beyond. One thing it doesn't do though, is display automatic transmission oil temperature. I have no reason to suspect the Prado doesn't capture it, but just getting it displayed via the Scangauge is another matter.
Have any of you guys been able to display this data as a Scangauge x-gauge in your FJCruisers, or maybe there is someone there with a 120 series Prado who has been able to do this? If so, can you let me know the gauge setup codes please? I have e-mailed Linear-Logic, but have not had a response at this stage.
Appreciate your help with this one.
Cheers
Greg
Western Australia.
Cheers
Greg
Western Australia.
