61 - 80 of 80 Posts
@Desert_Fox The frame has crumple zones...
I'd get some side braces made up to attach the bumper to the frame along the sides. Otherwise you're going to bend the frame horns on the first serious winch pull.
All Pro ran into this issue on their first builds. You'll notice that every vendor now has bumpers that tie into the frame rails on the sides, because the OEM horns are considered a crush point on the frame, and are not designed to hold up in a winching situation.
See here
I took the 'ol girl out for a nice excursion on Black Friday, and was super glad I had made those brackets. When coming up to China Wall, there was a big ass dip before the rock, I hit it straight on basically using the license plate and the two D-rings as skid plates. LOL!! Bumper & frame came out unscathed! Rock On Custom Brackets!
Here are the pictures:
Bumper
Winch mounted (control box moved later)
Final bumper mounted
Bracket Pattern created.
1/4" steel brackets cut - post grinding and minor alterations for fitment of brackets
painted brackets.
installed brackets.
NOW I feel like I can go use this bad boy!!
Nice! Good on 'ya for fixing an obvious flaw in their design. I only hope everyone else who buys one of these follows the same logic, assuming they are planning on using it for winching.
Where in CO are you?
On the Tundra, Smitybilt has an additional support bracket (part #93-7606 ) that bolts to the winch plate and where the OE tow hooks are mounted. There are a couple of other brackets but I am not sure if they are for the winch plate or outer bumper support.
Interesting that they would release the bumper for the FJC without this fix.
@shack, thanks for calling this out. @FJDragonChk thanks for the pics, I may be copying your design.
See here
Has anyone actually started to make a brace for this yet? Has anyone else had the same experience where the bumper has lost integrity when winching?
I'm really digg'n the homemade support brackets. As soon as it warms up here I'll need to get started on a set of those. Sure it's easier to buy a set, but making my own is more fun. Never really crossed my mind to make those myself, Thanks for sharing the idea.
Bumper
painted brackets.
installed brackets.
Do the brackets you fabricated connect to the Smittybilt bumper at all? Just wondering where the weak point is. If it's at the bolt on position or further down the horns. Have you tested your brackets? Thanks
I have a stock 2014 FJ that I'm going to replace the bumper on due to my wife :crying and I really like the Smittybilt bumper. Will the weight of the bumper affect the way the vehicle handles or make the front end lower than the stock position?
Bumper
painted brackets.
installed brackets.
Reviving an old thread here with some great information!
@FJDragonChk thanks for posting the pictures of the steel side frame support brackets that you made! Seems like a worthy addition. I was hoping you would be able to lend some more information as to what this bracket actually attaches to on the front most end of the FJC. From what I can tell in the pictures this support bracket does not actually attach to the Smittybilt M1 bumper itself...so does it attach to the winch plate? If so, where?
Maybe it is just harder for me to understand how the support attaches because I haven't pulled the trigger to purchase one of these yet and have never seen one in person... Any information (from anyone) will be appreciated!!!
There's another thread I ran across on this very subject because I have this bumper. I love the bumper and I've put it to the test. I sunk my FJ in a creek bed and locked up in sand and water up to doors. I had to block it and double the power to 20K to suck it out, ruined and frayed cable it was in such a bind and the frame never gave up.
I've hit trees and glanced off them several times only to knock the bark off the bumper revealing the un-damaged powder coat beneath.
The bumper gets a bad rap for some reason and don't understand it. Hell you don't even have to move the washer reservoir for the love of god!
I have spent the last two nights working on installing the M1 bumper. its on now ..ugh I said cuss word I forgot I knew.. the directions suck.. I had a hard time wanting to cut the headlight support bracket like the instructions say to.. but after the grill is back in it helps support the headlight on that corner.. I got shorted the control box mount brackets to the winch and called them and they are sending parts out asap.. like the look but what a pain in the arse.. the new square pods that come with it are really bright..they are pro comp 20 watts .. will post picture tonight
I hear ya, I found and lost my religion at least 3 times trying to install that beast. I still love her though, Bobby Brown and Ike Turner combined couldn't deliver the amount of beat downs I've given that thing and it barely shows it. :smoker:
Bumper
painted brackets.
installed brackets.
Reviving this thread again, I inherited an FJ with the M1 winch bumper installed & would like to install the reinforcement plates before hitting any trails, my questions are
1.Does anyone sell these brackets?
2. If no to question 1, does anyone have a template with dimensions marked to make fabricating them easier?
Thanks & Happy Holidays
Frank
61 - 80 of 80 Posts
