What kind of service did you do at 100,000 miles?
7.1K views 7 replies 7 participants last post by  DoWork
#1 ·
I'm an old head on the board and I've had my FJ since 2006. Needless to say I'm quickly approaching 100,000 miles and I'm wondering what others did as far as service at that milestone?
#2 ·
I would say just keep to your regular maint. schedule. I changed my transmission fluid at 50K and plan on it again at 100K I would think there shouldn`t be much else to do if you have been sticking to the maint. schedule. I may change my serpintine belt at 100K if I haven`t by then. I just flipped 71K miles on mine so it may be a couple years before I get there.
#3 ·
Most toyota vehicle need a timing belt around 100k. I just had timing belt and water pump changed on my 07 Tundra this year.
.............................................Roby.........................................
#7 ·
okay so I think its the pulley belt, oil change, spark plugs, front and rear diff, transfercase, transmission, filter, maf clean, throttle body clean, lube driveshaft zerks, check coolant levels and other fluids if you want to be thorough, im almost there at 98k miles.
