21 - 40 of 48 Posts
Great post on this. I just noticed my plastic cover hanging down and the rear strap is busted. I thought that particular strap just held the plastic cover on. DIdnt realize that was 1 of the 2 tank straps ... yikes!!!! Employing ratchet strap now, and ordering the replacement tank straps. Dang ... every time I think I'm done for a while!!
Discussion starter · #22 ·
Nice. My brother's '05 Tundra just broke one too.
This is a guide on how to replace the gas tank straps. I noticed one day while walking up to my FJ that the OE plastic gas tank skid was crooked. It didn't take too long to discover that one of my gas tank straps had broken! It looked to be very corroded, which surprised me a little because how clean I usually keep the underside of the FJ, there isn't a whole lot of rust. I'll get to why I think it broke near the end of these posts. My FJ is a very early March '06 build, so I imagine this could potentially be a more prevalent problem on FJ's in the future. Keep an eye on it!
Initially I researched a little but couldn't find a how-to or any part numbers. This has happened on a few member's FJ's but pretty rarely. The straps and procedure for each are for the most part identical. I'll show you how to do one, it's really simple but while looking for a solution it's nice to have pics and part numbers of everything. It can be done easily with a simple set of hand tools and a jack. Lets get started.
The problem:
My temporary solution :lol:
A big Thank you. I recently purchased a 2007 FJCruiser. And I noticed one strap had broken. This will help me to fix it. I am not a mechanic but this I will do.
Again thank you.
Thank you for this detailed walkthrough! I was able to replace mine today with the help of this post. I just thought the plastic plate was falling off, glad someone else knew better. Sadly I found a lot more rust under there. I guess my '07 in michigan is showing its age.
So I finally got around to starting this job tonight. My rear fuel tank Harbor Freight cargo strap has been hanging in there for 6 months now, wow!! The new straps have been sitting in a box on the shelf waiting for the right moment.
Right off the bat the flanged nuts that hold the plastic cover on the tank are so rusted that no socket in my entire collection will remove them. Not even my metric extraction sockets!! I had tools all over the floor but made zero progress. Unbelievably frustrating. The correct solution, again, involves my angle grinder. Dang it Toyota and all your rust!
I gave up for the night since I just wasnt in the mood for grinding away bolts in the vicinity of the fuel tank at that particular moment. I'm guessing that the dang tank strap bolts will be just as rusty and will need the same solution. I likely wont even bother putting a socket to them.
And now here I am looking at fuel tank skid plates instead of putting that silly plastic cover back in place. This was supposed to be a cheap, simple fix!
For reference, the replacement hardware part numbers appear to be:
90179-08241 (Qty 4) - nuts that hold the plastic cover to the tank straps
77644-35030 (Qty 2) - bolts that attach the driver's side of the straps to the frame [M10x1.25 threads]
I will probably just hit up the local Toyota dealership tomorrow to see if they have them on hand. Given that my FJ is my daily driver I dont dare start grinding away hardware and metal that I dont have a direct replacement for in hand.
A helpful YouTube video, even showing the stripping of rusty nuts!
Thanks to the OP and the added comments. I'll do this and my heater actuator next weekend I guess :(
So finished off the gas tank strap tonight and a few added comments to the video. Sorry, no pics.
  1. My tank was almost full so I had to hold it up with another tie down when I took off each strap. I used a wire to fish the tie down between the tank and skid plate snaking it through each hole. Saw a post on this in the 4-runner forum that gave me the idea. Fuel Tank Strap Replacement Tutorial (60+ Pictures) - Toyota 4Runner Forum - Largest 4Runner Forum (toyota-4runner.org) So now I had an extra tie down holding the tank up where the broken strap was. I could then take off the skid plate and my temporary strap over the skid plate holding the tank up.
  2. Tank strap bolts came out after soaking in WD 40 for several days. Took some persuasion with the impact gun running it in and out with more WD. The plastic skid plate did not go so well. 3 of the 4 nuts were too rusted to get the socket to fit and stripped. So I bought a set of bolt extractors from AZ for $30. Couple of whacks with the hammer to get it on the nut and they came right off with the impact gun. OEMTOOLS 3/8in Drive Bolt Extractor Set 5 Piece (autozone.com)
  3. This was pretty easy fix with the exception of all the rust in the face! Thanks to all the info here even an old man👴 in a wheelchair ♿can crawl around and get this done. Not saying this looking for props but to encourage others to try out a little work on their vehicle and save some $$!
Edit: Felt bad that I didn't post pics so I included a few. :) I did find it interesting that it didn't break on the spot weld like I thought it did. It was just super rusted and broke just below the spot weld.
Thanks for reviving this thread. It finally got me to replace mine which were sitting in the garage for a year. Just in time too. Rear strap woulda let go in a few weeks I think.
1174091
My 2007 has 120,000 miles. I rust proof regularly and hit the perforated end of the strap in the pic everytime. It's pretty accessible. Seems the straps are more prone to rust than our lovely frames. So for the new straps I removed the rubber sleeves and coated all metal areas with fluid film. Put back sleeves and installed. Then coated all joints, bolts, pins and surrounding areas with FF. They should last another 15 years but I'll pay extra to them. 😁
Reactions: MichEE
Just fixed mine. Rust makes everything even the most straight forward R&R a test of patience. Inner pins were seized as well.
I didn't even bother trying to remove the bolts for the plastic skid, they're too far gone to use even extraction sockets. Going to look for an aftermarket skid so I'm all ears for a recommendation.
Thread bump to say "Thank You" - just did this. Sort of. I mean, yours looks better, but I have all my fingers so I'm calling it a 'win".
Yes, I saw this: "This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread." considering newer posts you get from search engines give you nothing useful, consider this a +1.
-Ernie
The permanent fix:
The ratchet strap lasted me 2 weeks until I got parts and time to install them. The new OE part numbers you will want are:
77601-35110 - Front strap
77602-35050 - Rear strap
Which can be found on this diagram and come out to be about $90 before shipping: Fuel System Components for 2007 Toyota FJ Cruiser | Conicelli Toyota of Conshohock
As it turns out, the rubber fuel tank protectors are included with those part numbers as an assembly. Now, there is a non-oem kit on a few websites for a bit cheaper. I decided to stick OE, they lasted me 11 years after all. If you get an aftermarket variant feel free to let me know and post in this thread, I'm curious what they look like.
Here are what the new parts look like, I decided to just do both while I'm at it.
First you will want to remove the fuel tank shield retaining strap as noted in the picture below. I have no idea what this thing is actually intended to do but it makes life easier if you remove the 2 nuts from the body side. (circled in blue)
Then you will want to go ahead and remove the plastic fuel tank shield. There are 4 nuts, 2 are pictured below. Before doing so you will need to carefully remove your method of supporting the tank. (if any) In my case I took off the ratchet strap since my fuel level was practically empty and there wasn't a whole lot of weight.
Here is what it looks like fully removed including the retaining strap:
Once removed, use a jack to support the tank and push it back up a little bit:
Then remove the pin from one side of the strap, located near the center of the vehicle by the driveshaft:
Then unbolt the remaining side of the strap, this bolt was a pain for me to remove because how the bracket is constructed it sits in water and mud its whole life. Spraying with WD40 or something better makes a world of difference. You can easily shoot it horizontally inside that welded-on bracket and cover the threads inside the frame.
Finally, install the new strap! Exact procedure but reversed, nuthin' to it as I'm sure you are an expert by now. ;) You may need to jack the tank up a bit more to fit the new one on.
When you have that strap on, repeat for the other side (if you choose to replace both) and relocate the jack as necessary to support the tank.
Once finished reinstalling the plastic shield, and you've double checked that you bolted on the tank shield retaining wire doohickey, grab a cold one and enjoy your hard, money-saving work! :cheers:
My ground cable on the shield broke. Do you have any idea how can i fix it? What is its purpose?
Here's an update as of 2024-07-04
No links as they stop working and/or their marketing cookies make you click on stupid things that are not related:
Description:
Spectra Premium ST533 Fuel Tank Strap, Gray, Set of 2
Product ID (ASIN as well):
B01JINQSOQ
Manufacturer Part Number:
ST533
OEM Part Number (according to that terrible website)
‎7760135110; 7760235050
Disclosure:
Though I spend what appears to be half of my yearly income buying crap from Amazon, I in no way endorse the company or its website. I gladly welcome the day when we can get parts same-day in-stock at approximately the going rate, but that's never the case.
My point-of-view on the gas tank straps:
If you haven't replaced them yet, just do it, hopefully with an empty tank (I didn't have that luxury). Don't forget anti-seize for anything threaded and battery terminal grease for any ground you remove/put back in.
Keep yer stick on the ice.
-Ernie
You forgot something … 😉
Not wanting to criticize the genius that is Rick Green and Steve Smith, I've kept mum on the topic, but the reality is:
Duct tape is the handy-mans PRIMARY Weapon
Sheet rock screws are the SECRET weapon (Deck screws work too, but the former are ridiculously cheap)
for temporary fixes (that usually cause things to get worse if left that way)
The permanent fix:
I know this post is old but i was wondering if anyone else has had the problem where you order the strap from Amazon and it confirms fit but it just isn't big enough. I bought the strap kit: Dorman 578-422
after many attempts to get it to fit, I have given up and am returning it. The rear strap measured 76cm from centre of hinge to centre of pivot hole. Can anyone verify how long the replacement piece should be for a 2007 fj?
Don’t see anyone else using that kit. I was surprised how ’easy‘ it was since I had a broken strap and a full tank of gas. Look at the post I did at the bottom and you’ll see the Amazon ASIN. You can look that up, then verify years it fits in order to tell if they’re all the same parts by year. I’d be super surprised if they aren’t all the same.
21 - 40 of 48 Posts
