21 - 40 of 146 Posts
Jon,
It was great meeting you at Johnson Valley. I was amazed on how easy you made some of the obstacles at Clawhammer look. I was bummed to hear about your CV joint.
Thank you for all of the detailed instructions and pictures. As always, you share a lot of your knowledge with the rest of us. I've replaced birfield joints on a solid axle, but I am clueless at IFS.
Discussion starter · #24 ·
Thank you ALL for the positive feedback. That kind of stuff keeps me going. ;)
Nice write-up Jon. I didn't read anywhere if you replaced the inner seal on the diff. I always carry a spare set of seals and replace them when I replace the CV shaft. The seals are right and left specific, so you need two seals in your trail spares kit.
I did not replace the seal, but I looked at it really closely. I saw that the part numbers were different and I guess it's the outside diameter that is different because the shaft inside is the same. Why the heck they designed it that way is a mystery.
I've left off the skid plates for this week in order to peek constantly. ;)
This is good write up BellyDoc. The only thing that I can think of that you may want to look into is to see if you can remove the axle without disconnecting the calipers and hub assembly. After removing the spindle nut and disconnecting the sway bar, on tacos, you can remove the bolts(4 of them, 2 for FJ I believe) that connect the LCA to the spindle. The spindle should slide off the outer splines and out of the way. Then you have a direct shot at pulling on the cv assembly to remove it from the diff. I am pretty sure FJ is the same way but I haven't changed one......yet.:)
Discussion starter · #26 ·
I was hoping that someone *HAS* done it that way. I looked at the length of the splined outer shaft on the spare axle and the space inside, and my concern wasn't that I couldn't get the broken axle OUT... but that I wouldn't be able to get the less flexy new one IN. The CV joint has to flex to get it to go. I didn't want to take off the steering link and undo the upper control arm ball joint... though that would have been an option too. It typically leads to a need for a re-alignment which I plan to do anyhow!
Good point.
Awesome write-up Jon.
I've had the pleasure of doing this fine job on 3 occasions. Twice to replace an outer boot torn by a broken sway bar link and once to replace a broken axle.
Here are a couple of ideas for a "trail repair".
Field Note:The handle of the high-lift can be used as a cheater bar for removing the spindle nut.
Field Note: After removing the spindle nut. You can remove and replace the hub assembly by removing the two large bolts at the base of the knuckle, remove the steering rod, then pull the complete rotor assembly out to clear the axle. Swing it rearward, tying it off to the front body mount. Jon was not sure if this can be done
Note: If you are only replacing a boot, you must be very careful not to damage the inner seal when pulling off the hub assembly.
Field Note: I was able to use an 18" crow bar to "pop" the axle assembly out. The movement must be forceful using a quick snappy swing not a slow powerful movement. Remember you are attempting to "pop" the snap ring on the axle out of the inner cup.
Field Note: If you break the inner axle and don't have an axle assembly with you, it is possible to break the Birfield apart from the axle and use the outer spindle only to get home in 2WD. This requires total disassembly and reassembly but it will get you home. I now carry a complete axle assembly plus the old outer spindle as a secondary back up.
Thanks again for posting this up.
Reactions: iwashmycar
Sticky! Sticky! Sticky! Sticky! Sticky!
Did I say that this thread should be a sticky?
Seriously, I printed all the present pages of this thread and will hole punch and use as my field install guide in the event I ever need to do this (which I know I will at some point of life with my FJC).
Thanks Jon for taking the time to document this essential repair...
Thanks Doc'... I already have a spare complete
CV axle in my rig as backup, but did not have a
good writeup on the repair... Apprecate It !... :D
I have been planning on performing this job in my own driveway and supplying pics for a write-up, but you beat me to it! I can tell you that I have confirmed with TRDParts4U that he can provide full driveshaft assemblies, ready to be packed up in your trail kit, for $317.33 plus $19.99 shipping lower 48 states. I recommend to anyone that wants to do some serious offroading that they obtain the spare and then do a practice run at home, so much easier than "in the dirt" for the first-timers!!
Here is a drawing of the driveshaft assembly copied out of the service maual for any who want it. It was part of the write-up I was putting together.
Reactions: jorge
Great post Doc.
Thanks much...
:bigthumb:
Nice step -by- step !! My mother in law could read that and understand it enough to do it !! O.K ,,,,, maybe not. Still, nice job !!:bluecap: :bigthumb: :bigthumb: :bigthumb:
Beaucoup (virtual) reps to you for this. *excellent* :)
Nice write up Doc. Hopefully we won't need it at Rausch Creek Easter weekend but if we do, i'll be prepped. Thanks!
Thanks for taking the time to post this BellyDoc. Even neophytes like myself appreciate knowing what to do and how to do it once the 'poop hits the prop'!
Mike
