2007-2009 better?? or 2010 better?? , HP? or Torque? don't tell me is the same cause there is a difference little but there is one!
x2 a remote canister would be sweet. Do you have to remove the front skid plate to get to the filter on a 2010?Someone needs to come up with an oil filter mod for the 2010.
Although the 07-09 FJC's can run on regular unleaded, I believe the hp/tq numbers are only obtained with premium since that was what was originally recommended. At least that's if everything is going by the new SAE rating rules.That's actually not true, you can use any grade you want, i use 85 all the time in mine.
I suspect the torque curve (at least the lower end of it) on the 07-09 would look better. IIRC, peak torque comes on much earlier in the 07-09 than the 2010.Hey does anyone have dyno charts for both engines?
I realize the peak torque on the 07-09 engines is slightly higher, but the 2010 engine might have a better curve or the torque could come on a little lower. I'm interested to know what difference the addition of VVTi to the exhaust cams makes on the powerband.
Dual VVTi instead of single VVTi, 5W20 synthetic instead of 5W30 dino, roller rockers, oil filter type and location, external intake plumbing (pre-throttle body) and likely ECM tuning.What engine changes were made between the two?
Great information, ThanksMan after reading the attached. There are major and many changes/improvements made by toyota from the 2009 model to the 2010 model. Read it and you will know the facts. axles, diff's, frame, engine, steering. All improved and beefed up.
Thats interesting since all vehicles that are specified by the manufacturer for hp at 87 octane will always have more hp at higher octane since the fuel burns more efficiently. Otherwise you wouldnt need 104 and up for race fuel.Octane level doesn't designate power. It is to prevent knock and detenation.
