2007-2009 better?? or 2010 better?? , HP? or Torque? don't tell me is the same cause there is a difference little but there is one!
The 2010 takes 87 octane.
Minimum for 2009 and prior is 91.
To me that's the most valuable improvement.
For the rest check out the attached doc
The '10 model has slightly less Torque then the '07-09's.And they're tuned for more hp and torque so they can beast around stock what 07-09. Do with an aftermarket cai LOL
HEY! Page 39, section "b" is all about me!!! :lol:Man after reading the attached. There are major and many changes/improvements made by toyota from the 2009 model to the 2010 model. Read it and you will know the facts. axles, diff's, frame, engine, steering. All improved and beefed up.
Race fuels typically (not always) have higher octane because the engines they are intended for are built with higher compression and thus are more prone to pre-detonation (knock).Thats interesting since all vehicles that are specified by the manufacturer for hp at 87 octane will always have more hp at higher octane since the fuel burns more efficiently. Otherwise you wouldnt need 104 and up for race fuel.
Knock does play into it but there is plenty of documentation readily available to disprove your statement.
And this makes me laugh because the amount is what- 7ft/lbs. I dont think anyone would even notice that difference. Best part is, those numbers were conceived when using 91 octane so the engine could get more out of the fuel. When dropped to 87 the 07-09 model does perform well but less than the original numbers. The 2010 has more torque since its ratings were done with 87 octane from the start. So put in a TRD filter and tell me you feel the difference (I didnt) and thats more torque than what the original numbers differed. :cheers:The '10 model has slightly less Torque then the '07-09's.
DEWFPO
That may be true to an all out race car but when friend and I took his 98 Dodge Viper to a Viper day event at Beaverun track there was a huge difference with 104 octane than with 94 (both Sunoco). We only had one day and the first tank was a mixture but the second was all 104!!!Race fuels typically (not always) have higher octane because the engines they are intended for are built with higher compression and thus are more prone to pre-detonation (knock).
Race fuels, generally, provide their oomph through additives that increase their energy potential, but may require modification to the engine's fuel system management software (e.g. programmable ecu or a "chip") to take advantage of the fuel.
OK...back on topic. 2010+ all the way. :rocker:
The 2010+ engine does not have more torque.And they're tuned for more hp and torque so they can beast around stock what 07-09. Do with an aftermarket cai LOL
If both engines are tested on 87 octane- the 2010 will have the advantageThe 2010+ engine does not have more torque.
You said POO! :lol:What the POO!
The 2010 engine gains 12HP from using 91octane and the earlier engine only gets 3HP, that suxxxx.
:lol:
Actually, looking at the engine specs., I'm surprised there isn't a much larger increase in horsepower and torque for the 2010.
Lots of new parts in the heads alone (in fact they are totally different heads). Camshaft placement is entirely different. Intake ports are larger. Valve train is totally changed (roller rocker arms are used with hydraulic lash adjusters). Variable valve timing is now applied to the exhaust cams. Valve timing profile is changed considerably on both the intake and exhaust sides. Pistons are lighter and compression ratio has been increased. Crankshaft is different (4 fewer balance weights). Throttle valve diameter has been increased. Exhaust headers are more efficient. Plus a number of other smaller things.
Will it be better ? How so ? Do you mean 'new-out-of-the-box' or 'over-the-long-haul' ? Who knows...... the majority of differences on this new engine have raised the complexity level by another notch or two. I guess you have to ask yourself...... lately, does Toyota have an excellent reputation for engineering longevity into their ever increasingly complex creations ?
