21 - 40 of 124 Posts
Discussion starter · #21 ·
Very sanitary; nice work.
Thanks, I like it clean under the dash :D
Nice mount location... Thanks for the Info...
I think I may be making a stop at the marine
store on the way home...
Bandi Stay tuned, I'll be posting my Large CB Bracket install w/pics soon; along with the "Bandi" mount! It came yesterday, very nice work Bandi!
Very nice writeup!
The plate you made for the aux. box is very cool.
Wayne and I did mine a little different as far as the location of the box.
Auxiliary Fusebox & Twin 12v Outlets/FJ Cruiser - Welcome To YotaTech's Wiki
That Blue Sea box is a very popular unit that I have seen used in many a Toyota aux. fusebox installation.
If I add another box to the inside one day, I will have to try your way with the template, that is very slick.
Discussion starter · #23 ·
Very nice writeup!
Thanks! I love the duel install that you did, I am going to do the same a little down the road, thanks for the info :D
Very sharp work!!
BTW (nit) when working on the electrics, it is best to remove the NEG terminal from the bat, instead of the POS. I never could figure out why this was till recently.
If you remove the POS term, there still exists a potential for a tool to cause a short between the frame (NEG) and the POS terminal of the battery (POW!)
If you remove the NEG term, you have a risk of a tool causing a short fromthe NEG term to the frame, but all this would do would be to apply power to the vehicle electrical system briefly (which may not be a good thing, but probably less of a hazard than a 1000 amp short)
A short between POS of the battery and the frame when the negative terminal is still connencted is always enlightening and memorable.
If the neg is disconnected, a tool short from battery POS to the frame is not a short of the BATT, since there is no return path to the negative term of the batt.
Discussion starter · #26 ·
Very sharp work!!
Your right :) It's been a while since I did an automotive electrical work. Thanks, I'll make the change:D
Excellent job. Rep points for you. 1 question. Why 125 amps? Sounds like a lot. Will your wire carry that much current?
Awesome mod and writeup!
Another great one from an FJForum member!!
what a community!!
T
Discussion starter · #29 ·
The type of fuse block I used spec'd out to put an inline 125 amp fuse between the source and the fuse block. I just thought I would pass that info on to anyone that planed on doing the same thing. I haven't done it yet, but i will put in a high amp fuse somewhere in the engine bay. I'll update this post when I do. Thanks for the Rep Points, they are allways welcome :D
Great job and super write-up, shadow!!
Question: Do you know how to add an additional auxillary fuse block (like yours) that would be activated by the ignition switch being on (like the radio, A/C, wipers, etc.), and then turn off everything on that block when the ignition is turned off.
Given the choice, I'm not big on tapping into existing circuits (Add-A-Circuit) unless I really have to either. And, there are only so many available "Accessory" circuits/fuses anyway.
A heavy-duty relay from the battery to the aux fuse block triggered by one of the "key on" circuits??
That method is what I have read.
You hook up the relay like you would for a set of lights, but without a switch.
You could use a fusetap to the incab fusebox to powerup the relay when the key is on.
Discussion starter · #34 ·
Bump :D
Discussion starter · #36 ·
I need to do some clean-up on mine and was not sure where to mount an aux. fuseholder, this will be just the ticket. Thanks to Shadow and also Corey for the links to the parts.
Thanks, Glad I could help out :D
Discussion starter · #37 · (Edited)
****************UPDATE******************
I have installed an inline 60 amp Fuse between the Battery & Fuse Block. This will help insure of any High amperage short to the fuse block inside the cabin. The Fuse block said to install 125 amp fuse. I tried finding one without ordering online, and found the largest I could find locally was a 60amp inline fuse. A 125 amp has to be huge, I think a little over kill myself. I went with the 60amp, it should suffice. The following are some pics of the inline fuse installed for everyone. I installed it a while back and told everyone that I would update the thread when finished. Sorry for the delay, I took some pic's this morning.
I hope this helps everyone :D I also updated the first post to reflect this update :cowsmile:
Discussion starter · #38 · (Edited)
Where is my pic's ? whats going on with the server?...Never mind, I fixed it :D
Discussion starter · #40 ·
