Haha, thank you for the opinion =).
No reason for the kings to cost that much more. I run Kings now but have had the fox and they are a fine product. I doubt you could find a better company to work with than king. They have fantastic reps. BTW more off road events have been won on kings than any other shock.........
Good, so you tried them both and fox is still a "fine" product. I know, the distributor here is a very nice guy, free revalving after a year, lots of stickers, free bushings replacements, reservoir pipes, clamps, etc. etc. for a year too.
I wouldn't go with "more off road events have been won on kings", Foxes are nearly never seen, I suggest you do some more SCORE watching and see the fox/camburg trophy truck, now that's a beauty.
I have the OEM kings with reservoirs and camburg UCA and they ride awesome I have no complaints. I chose kings mainly because if their reputation , looking at all the multi million dollar trophy trucks and sand rails using them tells me that they must know something. And lets face it that is a sweet looking blue!!
Thank you for sharing your opinion, again read my above comment on what SandFJ has said.
The ones on All-Pros website are blue. The picture on their website is black but if you add it to your cart and then click on it from inside your cart, it will show the actual blue color. The black ones are long travel and only work with their LT kit. It's not as bright as King's blue, but it's still blue. And the spring on it is a 600 lb/in and are adjustable up to a 3.5" lift. When you order from All-Pro, you would get 10% off any other front suspension components you order such as UCA's. :bigthumb:
Oh I see, I think they look like the ones that were on Todd's FJ (Air2air).
600lb sounds just fine for my ride or for any other pre-runner to be ride, 3.5" lift always loved a nose-up look. Thank you again for the details, cheers buddy!
I'd go with a long travel kit if your into jumping.
That was my route except I got told that such kits won't be allowed for a car to be registered on an annual basis because of the "welding" and because of a few laws, unless I go with the routine off taking off the LT and then registering the car and then putting it back in which would be annoying.
I'd be quite interested to see where you got this. FOX has been around a lot longer than king (25 plus years), so I find this quite hard to believe. Got a reference?
You can look at fox's website and see how many folks they had on the podium last year. Regardless, I don't see how that makes it clear by any means that one shock is better than the other, alot more goes into a race than just 4/8 shocks.
I'll play devils advocate. I'd recommend looking at a few more trophy trucks as FOX has dominated the overall points in SCORE for a number of years. Many of the TT and shortcourse folks run Fox shocks (Robbie Mac, Johnny Greaves, McMillin, Campbell, etc.).
Again that being said, it wouldn't be the reason I would go out and buy a Fox shock.
My post isn't to knock King or Fox or to promote King or Fox.
The reason you see a lot of King Shocks in desert racing is because they have strong support and customer service. They are out at most of the large events and do tuning for folks. Definitely impressive and I've heard good things about their customer service :bigthumb:
Fox is out at fewer events and generally sponsors/is on the big names/vehicles within the industry. Last short course race I went to Fox was there with their trailer, but not a single fox representative around. All that being said I'm aware of Foxes background and they've been an industry leader for quite some time. In the early days billstein and other mfgs were highering away many of the Fox engineers since they were leaders in offroad shock development and could transition that to onroad and track applications as well (basically ground breaking stuff for the track cars).
Either one makes a fine product.
Back to my original point if the shocks are valved similarly and running the same rate coils you'd have a hard time telling the difference. That's why folks tend to say "pick a color". The only added value I potentially see by spending more for the kings is the 2.5"body shock on the rear which may be of benefit to you. It doesn't buy you more travel, but would be of use if you are overheating your shocks. You should be able to setup either coilover for the same amount of travel, by working with the mfg or rebuilding it yourself.
In my opinion, your money is best spent tuning the suspension, getting the right coil and valve stack, than trying to pick between shock mfgs. You aren't building a race truck here and either one will be reliable for your application.
Toss ICON, Radflo, SAW, and ADS into the mix as well. Slight differences in manufacturing and valving philosphy, but pretty similar across the board when it comes to our applications. I personally like FOXKINGICONRADFLOSAWADS shocks...work better than anything out there :bigthumb:
Couldn't agree more =).
Crap I forgot bilstein in my favorite shock name title. Toss them in too!
In regards to tuning it either comes down to your capabilities, the local shops, or the mfgs. Being in the UAE you might want to give the customer service aspect some strong consideration. Several of those mfgs mentioned above are more adept at dealing with the little guys rather than only providing customer service major corporations or race teams.
Good luck with your decision. Out of curiousity are there any UAE legal requirements which prevent you from modifying the suspension with or front and rear design?
Well yes I did answer that above. That was my route except I got told that such kits won't be allowed for a car to be registered on an annual basis because of the "welding" and because of a few laws, unless I go with the routine off taking off the LT and then registering the car and then putting it back in which would be annoying.
You really need to go with a long travel setup for the type of offroading you do. With a stock configuration (travel) you really won't notice a difference between the top manufacturers. The travel on them will be very close to the same. In the rear the shocks are not really what limits your travel. The control arms, bump stops, and panhard bar all play a roll in the travel.
You are right and read my above comment for FJNewB.
You can always go with the All Pro LT kit for about $8000 with all the bells and whistles like Old Cruiser has on his FJ. They can combine LT Fox Shocks. You'll need extended axles to retain the 4wd...
Yup, read my comment for FJNewB.
All I can add is that the Fox 2.5" extended w/resivoir and 2.0" piggy back system has turned my rig into a twisty highway, dessert road, sand dune and rocky trail "Mashing machine!
That sounds great, thank you for your opinion!
銀チタン;2232429 said:
LT in the dunes for the win!
A lot more to debate than Fox vs King for the dunes.
Haha true that.
From what i've read when it comes to lifts, I'd say King is better and well worth the money.
Opinion appreciated even a little bit of what you experienced with either of the shocks would be great to defend your point too.
Can you elaborate on what led you to that conclusion? I'm sure that many would enjoy the reading you are refering to to educate themselves as well :bigthumb:
:clap:
銀チタン;2232487 said:
Referring.
Here's a side by side, though I don't know that a conclusive decision could be drawn, unless wise to the ways to material properties and hydraulics.
Fox Vs. King
Had a look at that and that's impressive, they chopped them down to bits and pieces and explained everything that both companies use for their shocks. :rocker:
...probably a lot of what's in this forum. I enjoy reading yours and DeLancy's posts/threads. They are very informative and you guys seem to know what you're talking about, very technical, interesting and HELPFUL. I gotta say, though, I notice you ask people to list their references quite often. It may dissuade others from posting their advice/input (which is what the OP is asking for). I guess I agree with FJX200 because, hey, I got the KINGs so I must've compiled enough information to make that choice somewhere. I can't remember or have the inclination to research and list EVERY SINGLE PIECE of literature I've read that has led me to a certain conclusion and I don't believe other forum members want to. I don't post much because I don't know ish and so I ask a lot of questions. I think at this point we all know we are not nearly as knowledgeable as yourself and a few others when it comes to our toys and look to you guys for advice. NO sarcasm there, that's from the heart. Anyway, see you out on a trail some time. Peace! :bigthumb:
:X
銀チタン;2232542 said:
It's Delancy. Just saying. Haha.
I've no experience with Fox, but do with King.
Awesome ride quality and construction quality was top notch, in comparison to many other brands I've installed or visually seen. The resi's are large, coil retainers are properly sized. Lower shock eye is the largest I know of (an assumption that translates into strength) the upper bushings on the rear shocks are tougher, and the retainers are machined, not oversized washers.
Plus the coil nut is the easiest of any to adjust inside the confines of the FJC coil bucket.
Great product, but their customer service doesn't parallel, and the reason for the swap to Radflo's, whose customer service is the best in the business. Period.
Plus, blue is for Baz's Bozo.
Edit: I've swapped the rear bushings and clear aluminum bushing retainers from what Glenn sent, to the King's some time ago.
Another advantage King has, pertinent to the particular set up I have, is the bump can mounting method for air bumps. A lot cleaner, in my opinion.
Thank you Chris (was it?) for sharing your opinion too!
Well, it's a hard debate and don't really know what I'm going for but I'm gonna ask the guy to look me up into some race series shocks, if they're worth it then I'll go for 'em otherwise if the ones he have are the OEM then no-no kings, hooray for fox.
